Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 05:53 PM   #11
1988TTOP
Vehicle: 1988 GT TTOP
that wire u need u r goin to have to go to a junk yard or just put a spade connector on it
__________________
1988 Gt TTOPS 1 1/2 IN LOWERING SPRINGS KYB ADJ SHOCKS MSD COIL FRPP WIRES LONG TUBES O/R X PIPE FLOWMASTERS KING CORBA CLUTCH MGW SHORT THROW SHIFTER F CAM CRAN VALVE SPRINGS ROLLER ROCKERS 650 DP HOLLEY UPPER & LOWER CONTROL ARMS 4.10 GEARS
1988TTOP is offline   Reply With Quote
Old 09-14-2009, 05:58 PM   #12
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
__________________
mattdel is offline   Reply With Quote
Old 09-14-2009, 06:05 PM   #13
g2_5point0
Vehicle: 1990 LX
yeah, that looks about right. either the ignition switch is shot, or i have no power running through the white/pink wire. im going to grab those security torx bits tonight and change the switch out tomorrow and see if by some miracle it works.
__________________
1990 LX 5.0 - BBK shorties w/ O/R H & Flowmaster 40's.
g2_5point0 is offline   Reply With Quote
Old 09-14-2009, 06:10 PM   #14
1988TTOP
make sure both the connectors r plugged into the safety switch that got me once when i had the same problem
__________________
Old 09-14-2009, 07:07 PM   #15
g2_5point0
Vehicle: 1990 LX
both connectors are in the safety switch. however, the wire that goes from Red/Lt blue to white/pink is dead at the ignition switch. So thats why the guy had to just wire a switch in. Even with the new ignition switch in, jumping the solenoid directly to the correct pin on the ignition switch doesnt work. I have to see where the Red/lt blue to White/pink is going wrong, because it's dead.
__________________
Old 09-14-2009, 07:10 PM   #16
mattdel
mattdel's Avatar
Vehicle: 1986 LX
NSS on the trans
__________________
Old 09-14-2009, 07:12 PM   #17
g2_5point0
Vehicle: 1990 LX
NSS comes on 5speeds too? So if that's fried, that wire dies out?
__________________
Old 09-14-2009, 07:18 PM   #18
mattdel
mattdel's Avatar
Vehicle: 1986 LX
yup. wont complete the circuit. bypass it to be sure, just link the two wires together with a jumper wire.
__________________
Old 09-16-2009, 07:01 PM   #19
g2_5point0
Vehicle: 1990 LX
for anyone who searches this topic in the future, this was my solution :
after hours of searching for wires and checking sensors and whatnot, it all came down to the play between the keylock cylinder and the ignition switch. the switch was too far from the keylock cylinder, even if it was just a fraction of an inch. So when the key was turned to crank the motor, it wouldnt engage the starter!
Thanks for everyone's help. it is working flawlessly now!
__________________
6566, 86, 90, broken, convertible, cylinder, ford, ign, ignition, installation, key, lock, mustang, parts, remove, stuck, switch
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
