Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 02:42 PM   #1
jesran48
Vehicle: 1993 Mustang GT
Default 302 to 460 Swap
I previously own a 93 Mustang GT without a 302 and tranny. While looking for a 302 motor and trans, i stomped upon a 460 motor. Motor is complete.
My question is - What else is needed to install this motor and how would I mount up a t5 tranny to it?
Sorry if this is the wrong section to post this.
jesran48 is offline   Reply With Quote
Old 09-14-2009, 04:40 PM   #2
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
Well,you would need engine swap mounts,headers,oil pan,pick up tube.I believe Motorsport and some others make a kit to do that.I have done one, but it was along time ago.The engine fits surprisly well.I think you use the same crossmember,just have to grinds the weld if is so.For the transmission you could look into a Lakewood bell housing and see if they make a conversion bell housing.I know that they make a C-4 bell housing to put one behind a big block.Just use a 4 cylinder throttle cable as they are longer and will reach with a little slack.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
Old 09-14-2009, 07:33 PM   #3
scatfox331
1991 Ford Mustang
scatfox331's Avatar
Vehicle: 1991 ford mustang
you would probly wanna go with somethin a little beefyer than a t-5 behind a big block imo.
__________________
f**k 'em if they cant take a joke! -tucker max
scatfox331 is offline   Reply With Quote
302, 460, 50, 83, big, block, conversion, edge, ford, kit, motor, mounts, mustang, sn95, swap, t5
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
