Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-15-2009, 09:19 PM   #1
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
Default help me open up my transmission
so i pulled the trans to put in a new clutch and i noticed my speedo gear was chewed up. this is the third one that has messed up. so my only guess would be that it is the drive gear. even though i don't think the orginal speedo gear was bad when i had the 2.73's in. ever since i put the 3.55's in the speedo gear is getting trashed.
i need to know how to access the drive gear, or really need to know how hard is this going to be? i have access to alldata, so i know if i run into trouble i can look at the diagrams and what not, but i would really like to hear it from a person. i know fivepointohh has torn apart one, so hopefully he'll chime in as well. thanks guys
__________________
fresh 306,Trickflow top end kit, T-5, 3:55's, Mac C/C plates, Eibach pro springs, Strange 10 ways, Pro 5.0, 24lb injectors, BBK 75mm tb, Pro M Maf/CAI, Walbro 190 lph, holley FPR, tubular k member, bbk shorty headers, o/r h pipe with no cats, flowmasters, 17x9 Cobra R, shaved doors, antenna and emblems, SVO hood, Saleen spoiler, no backseat and probably more
soon to come:
100 shot, rear suspension and new tires
crusin92red5.0 is offline   Reply With Quote
Old 09-15-2009, 09:28 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
take the 4 bolts off the shifter cover, remove it and inside you will see a block where the shifter ball goes into, on the top is a little hole in which a role pin is in, tap the roll pin all the way down and out and pull back on the block as if you were to shift a gear and it'll pull off the rail almost all the way, to get it the rest of the way off remove all the bolts holding the tailshaft on then pry the tailshaft housing off and the block will come off the rest off the way, then you will see the drive gear on the output shaft, tap it off, a clip holds it in place, reverse procedure to reassemble
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 09-15-2009, 10:36 PM   #3
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
Quote:
thanks alot, i was hoping that i wouldn't have to disassemble the whole thing to access it. sounds like it shouldn't be that hard.
does this sound like the problem i'm having of chewed up gears?
__________________
soon to come:
Old 09-15-2009, 10:42 PM   #4
mjr46
mjr46's Avatar
Vehicle: 85 mustang
shine a light in the hole and inspect it
__________________
Old 09-15-2009, 10:56 PM   #5
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
the drive gear doesn't look chewed up at all atleast the side i saw, i don't know the other side of the gear.
__________________
soon to come:
Old 09-15-2009, 11:06 PM   #6
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
__________________
soon to come:
Old 09-15-2009, 11:18 PM   #7
mjr46
mjr46's Avatar
Vehicle: 85 mustang
are you using a gear for an auto tranny..IIRC THE t-5 gears are a tad longer
__________________
Old 09-15-2009, 11:37 PM   #8
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
if i am, i'm gonna be pissed at 50resto, cuz they've sent me that last two, and i know i said t-5. the new speedo, pilot bearing, clutch, and throw out bearing should be hear tommorrow or thursday so we'll see. i thought it looked short when i first got it.
__________________
soon to come:
Old 09-15-2009, 11:43 PM   #9
crusin92red5.0
1992 Ford Mustang
Vehicle: 92 vert
another guy locally, wrote this
"It sounds like its the rear shaft bearing going out due to the symptoms you describe with the roar, vibration and the speedo gear getting chewed up all the time"
could it be a rear shaft bearing? the noise i am having did not exsist before i pulled the motor and did the hci and put the tranny back in, so i know his statement is not totally correct.
__________________
soon to come:
Old 09-16-2009, 12:11 AM   #10
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you'd have to have excessive play at the rear bushing/tailshaft area, some play is normal wear and won't cause that
__________________
50, alot, bushing, forums, gears, mustang, open, removal, sleeping, t5, tailshaft, tranmission, transmission, transmisson, wont
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
