Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-21-2009, 05:22 PM   #1
Will86
Vehicle: 93 Ford Mustang
Default will not hold idle, runs too lean
Hey guys,
I have a 93 Mustang Cobra and just finished installing a bunch of mods including AFR Street 165cc heads, trick flow upper and lower intake manifolds, crane cam (part # TFS-51402000) 24lb venom injectors, and a BBK fuel rail with an Accufab adjustable regulator.
I was able to get the timing dialed in and break in the cam however I cannot get the engine to hold an idle. If I slowly back off the throttle the engine will idle rough around 900 then eventually die. If I rev the motor up and let the revs fall naturally the motor will instantly die. I pulled the some of the plugs and the motor looks like its running extremely lean.
I used to have a C&L 76mm mass air flow housing, however, it ran better when I swapped the stock housing back on the engine.
I originally thought my issue was vacuum related. I checked all lines and gasket surfaces over and was unable to find and sources of vacuum leak. I also had a master mechanic look at the car and he ruled out a vacuum leak. Even if the injectors were to small for this setup I doubt their duty cycle could be maxed out at idle. Has anyone else run into this issue or have any suggestions on how to remedy this problem? Thanks!
Will86 is offline   Reply With Quote
Old 09-21-2009, 06:39 PM   #2
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
fuel pressure?
__________________
mattdel is offline   Reply With Quote
Old 09-21-2009, 08:01 PM   #3
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
base idle relearn proceedure
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-21-2009, 08:23 PM   #4
5.0stanger
5.0stanger's Avatar
^^agree, turn up the base idle. You have the IAC hooked up? Ever try and pull the codes?
__________________
-Kyle
5.0stanger is offline   Reply With Quote
Old 09-21-2009, 08:45 PM   #5
Will86
Fuel pressure is nearly maxed. The IAC is plugged in. To adjust base idle I just turn the screw on the TB right?
Old 09-21-2009, 09:14 PM   #6
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Quote:
why is your fuel pressure maxed? it should be at 39psi
__________________
Old 09-21-2009, 10:28 PM   #7
bosspsd
I will be watching this one as my 1990 is acting very similar. Only when hot and not all the time.
bosspsd is offline   Reply With Quote
Old 09-22-2009, 08:04 AM   #8
Will86
Quote:
I have the screw on the regulator almost all the way in. I still need to put a gauge on it though so im not sure of the exact pressure.
Old 09-22-2009, 12:38 PM   #9
1ATony
Sponsor
1ATony's Avatar
Vehicle: 92 Ford Mustang
Quote:
If it surges could be the EGR,or TPS too
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Our Our Ford Mustang Parts
1ATony is offline   Reply With Quote
Old 09-22-2009, 01:31 PM   #10
mattdel
mattdel's Avatar
Vehicle: 1986 LX
get a gauge on there before you do anything else. 39 psi with the vacuum disconnected and capped.
__________________
1990, 40, 50, 92, adjustable, car, ford, hold, hot, iac, idle, lean, mustang, running, runs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
