Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-21-2009, 05:37 PM   #1
RICEBORDEAUX
RICEBORDEAUX's Avatar
Default Won't stay running
For some reason my car will not idle right away I have to give it gas alot of time to get it going I broke my accufab throtle bottle and it was a 70mm now I have a 65mm Edelbrock and it ain't been right every since does it have something to do with the size of the throttle body or do I have a vacume leak or something somewhere....
__________________
FORD RACING CRATE 347 STROKER W/ SVO SPORTSMAN BLOCK, 3.73 GEARS, EDELBROCK ALUM HEADS, TRICKFLOW INTAKE, B-CAM, 30LB INJ, 76MM C-4 STOCK SUSPENSION 12.71 AT 108....MY SETUP COMING SOON........
RICEBORDEAUX is offline   Reply With Quote
Old 09-21-2009, 06:01 PM   #2
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
You may need to set cold idle.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
Old 09-21-2009, 07:26 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
the throttle blade may not be accuratly set even though idle in theroy is controlled by IAC motor, perform a base idle reset
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
1983, 2000, 351, 50, 95, cold, fairmont, ford, idle, idling, mustang, running, stay, windsor, wont
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
