Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-25-2009, 08:00 PM   #1
sgarrelts01
Vehicle: 1994 Mustang GT
Default What Size Push Rods
Figured out the problem i was having was my cam.
Put a flat tappet cam in now i have to convert it over to roller.
if i use this cam
COMP Cams CL35-328-8 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
and some 1.7 rockers
What size push rods will i need.
sgarrelts01 is offline   Reply With Quote
Old 09-25-2009, 08:21 PM   #2
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
http://www.summitracing.com/parts/TFS-9001/
__________________
mattdel is offline   Reply With Quote
Old 09-25-2009, 08:57 PM   #3
sgarrelts01
Quote:
Originally Posted by mattdel View Post
Thanks but The 94 mustang push rod length is 6. something. Do they make smaller checkers
Old 09-25-2009, 09:31 PM   #4
Bubba 95SN
Vehicle: 1995 Ford Mustang GT
Jegs 555-80680 6"-7.170" $11.99 has everything needed.
Bubba 95SN is offline   Reply With Quote
Old 09-25-2009, 09:38 PM   #5
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
stock length is 6.250, you need one adjustable from 6-7 ish range, no if ands or buts length must be measured, and what had you done???
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-25-2009, 10:00 PM   #6
sgarrelts01
Quote:
I put a flat tappet cam and lifters in, it wasn't a roller block or anything, but the cam i got changed the firing order, an it threw my computer into wack, making it run all messed up
Old 09-25-2009, 10:07 PM   #7
mjr46
mjr46's Avatar
Vehicle: 85 mustang
so you have a flat tappet block??? there are very few flat tappet cams available with the h.o firing order
__________________
Old 09-25-2009, 10:59 PM   #8
sgarrelts01
Yeah i heard there are some, but i can't find any. So now i have to pull it all a part, well not really just the front an top, and make it all roller now.
Old 09-25-2009, 11:03 PM   #9
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
http://www.summitracing.com/parts/TFS-9000/
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-26-2009, 09:10 AM   #10
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
to make it roller, there are two options...option 1 expensive 450.00 link bar retro fit lifters and roller cam.......option 2 reduced base circle cam and stock roller lifters and hardware and tap valley for spyder retainer, if interested in option 2 I have retro fit cam = comp thumpr cam .530/.515 lift but with the cam it still reccommends the retro expensive lifter = these
http://www.summitracing.com/parts/CCA-8931-16/
anyway I have cam and springs...175.00 for both if interested
__________________
331, 50, 6400, 94, base, cam, circle, flow, ford, measured, push, pushrods, rod, rods, roller, size, small, stock, stroker, trick
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
