Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-25-2009, 10:09 PM   #1
wterrell
Vehicle: 94 GT
Default I don't know what the problem is now. Help!!!
1994 GT 5.0 144,000 miles. Automatic
smog pump line was split, took smog pump out, plugged all hoses that used to be attached to the pump. At the same time I put in a cold air intake. Now it will not get above 3,500 rpm. idle is perfect. Also I cut the cats out one was in pieces inside and plugged. (that didn't help)
wterrell is offline   Reply With Quote
Old 09-25-2009, 10:10 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
did you clean the maf sensor??
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-25-2009, 10:44 PM   #3
wterrell
Vehicle: 94 GT
Yes,
just found on another forum it is a big chance it's the distributor.
Old 09-26-2009, 05:17 PM   #4
Bubba 95SN
Vehicle: 1995 Ford Mustang GT
Is the filter now in the fender(cold air)? If it is they make cold air mass air flow meter get one.
Bubba 95SN is offline   Reply With Quote
Old 09-26-2009, 06:26 PM   #5
wterrell
Vehicle: 94 GT
I think I found my problem, or part of it any way.
were my smog pump line was leaking, next to the head. the hot air looks to have melted the connector. for what i think is some kind of vacume valve. it has two vacume lines that t off one goes into fire wall other goes under the intake manifold. i took pics will post when i figure out how to.
Old 09-26-2009, 06:38 PM   #6
wterrell
Vehicle: 94 GT
pics in profile album
Old 09-26-2009, 07:42 PM   #7
wterrell
Vehicle: 94 GT
The part is the Charcoal Canister/Solenoid it's part # E4ZF-9C915-AA.
could this be causing the motor not be able to rev above 3500 rpm without misfiring.
Old 09-26-2009, 07:52 PM   #8
mjr46
mjr46's Avatar
Vehicle: 85 mustang
^^^^^no....all that does is purge fuel take vapors stored in the canister and allow them to be evacuated and burned in the cumbustuion chamber
__________________
e4zf9c915aa, flow, purge, sensor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
