Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-29-2009, 12:51 PM   #1
wildsurfer92
Vehicle: 1992 Ford Mustang LX Vert
Send a message via AIM to wildsurfer92
Default Brake upgrade!
Okay can anyone throw out a list of everything needed to do the 73mm i believe caliper upgrade and where I can get it all from. I can get stuff through napa I just dont know what all i need. Thanks
__________________
1985 Mustang GT t-tops, k&n, msd ignition, short throw shifter, steeda lowering kit
1992 Mustang LX convert, bbk o/r hpipe, flowmaster american thunder, 3.73 gears
wildsurfer92 is offline   Reply With Quote
Old 09-29-2009, 01:38 PM   #2
luckythirteen13
luckythirteen13's Avatar
you need 73mm calipers and pads. thats it. it would be a smart idea to get a larger mc as well. youll also need a bunch of brake fluid if you put in a new mc because you will need to bleed the entire brake system
http://mjbobbitt.home.comcast.net/~m...tang/4lug.html
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 09-29-2009, 08:22 PM   #3
wildsurfer92
what size or kind of master cylinder would i need?
__________________
Old 09-30-2009, 02:51 AM   #4
luckythirteen13
http://mjbobbitt.home.comcast.net/~m...ustang/mc.html
__________________
Old 09-30-2009, 04:59 AM   #5
wildsurfer92
awesome man thanks alot! ill let you know my progresss
__________________
Old 10-07-2009, 05:02 PM   #6
wildsurfer92
hey i didnt see it anywhere in the links, but if i switch to the new calipers can i still run the regular 92 mustang brake rotors???
__________________
Old 10-08-2009, 03:11 AM   #7
luckythirteen13
Quote:
as long as its the 73mm calipers they mention in the link, then yes
__________________
Old 10-08-2009, 03:24 PM   #8
Michael Bachman
Vehicle: 1986 Ford Mustang GT
Get the calipers and master cylinder. I also went with stainless steel brake lines up front and a proportioning valve to dial in the front/rear balance. I also had to get the parts for the 11 inch rotors and rear disc brake conversion as I have an 1986 GT. That was a must as I was doing open track events. I ran that combination for a couple of years. My 10 inch rotors and rear drums that were stock on the 1986 5.0's didn't due the trick on the track and I fried them on a regular basis.
I have since upgraded yet again to the M2300K Mustang Cobra Brake Kit. Pounding on the shock tower to get the volume booster installed was a freakin' nightmare.
Michael Bachman is offline   Reply With Quote
Old 10-08-2009, 03:34 PM   #9
Michael Bachman
Just say you need the calipers and master cylinder for a 1988 Lincoln Mark VII. That will get you the 73 mm calipers and correct master cylinder. That's what I did. Same year for the proportioning valve if you want to go with that. You will need some fittings for the proportioning valve. Stainless Steel Brakes has the stainless steel lines and you could get the valve from them as well.
http://www.ssbrakes.com/
1985, brake, mustang, upgrade
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
