Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-02-2009, 11:42 AM   #1
1slick88cat
Vehicle: 1988 mercury cougar
Default Tweecer rt or Anderson pms
What do you think and what are the disadvantages of both
1slick88cat is offline   Reply With Quote
Old 10-02-2009, 11:51 AM   #2
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
I here the new Moates Quarter horse is better than both. The same people or person that designed TweeCar designed the software that is needed for the Quarter horse. It will also save a few dollars over the TweeCar.
TrimDrip is offline   Reply With Quote
Old 10-02-2009, 07:54 PM   #3
Liquid_02
Vehicle: 92 GT
Quote:
+1 on quarter horse. I have the PMS in my car and I love it, absolute only dis-advantage to the PMS I've found so far is the cost. If I did it again I'd probably use quarter horse.
Liquid_02 is offline   Reply With Quote
Old 10-02-2009, 11:49 PM   #4
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
I have the quarterhorse. Ive used the Tweecer, and it will NEVER go in my car again.
and theres no F'ing way that im paying for a PMS, especially when the quarterhorse does MORE stuff
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-03-2009, 01:15 AM   #5
luckythirteen13
luckythirteen13's Avatar
i have the pms and its very easy to use. if i had to do it all over again, id probably go the ms route just because its so much cheaper. also, tuning with maf is expensive, especially if you change your combo and get bigger injectors
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 10-03-2009, 10:48 AM   #6
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Quote:
The version 2.8 and newer of the MS2, use a ford maf. so if you were smart about the tuning, you would buy a maf that will work no matter what you change, like the SCT2800BA. and all you have to do is change your injector high and low slopes and breakpoint values.
your PMS might not let you do that, because its an overpriced piece of crap
__________________
Old 10-03-2009, 01:28 PM   #7
luckythirteen13
i think its geared towards people who know nothing about tuning because you dont need to know jack to tune with the pms. one nice thing is that it can tune based off of boost as well as when nitrous is spraying or not
__________________
Old 10-03-2009, 03:31 PM   #8
AdderMk2
MF Attention Whore
AdderMk2's Avatar
merasquirt, even while running with a maf, can still referance boost through the normally included MAP sensor. and the MSnS firmware can be used to CONTROL your nitrous and boost levels.
and although the quarterhorse uses the stock eec, and realy doesnt use any extra inputs, a DATAQ can be used for nitrous trigger sensing, boost level, and even wideband input.
i actually have mine directly run into my stock harness, and datalogged along with all other sensor data that is recorded.
the moral of the story is... Anderson PMS is just as outdated as the ford letter cams, and just as over-rated as a tom hanks film
__________________
Old 10-03-2009, 06:35 PM   #9
jthorn9
CSMG Moderator
jthorn9's Avatar
Vehicle: 1995 Mustang GT, 2000 Mustang
I had the PMS and sold it, didn't like it and it was a pain to tune with, layout was fairly easy, but the learning curve was huge. But I wasn't running version 2.8 either, I think it was 1. something back then.
__________________
Trinity 99 Mustang SVT Cobra
Selena 95 Mustang SVO GT-40 1.5L 11PSI Kenne Bell Supercharger
jthorn9 is offline   Reply With Quote
Old 10-04-2009, 04:08 AM   #10
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
Quote:
I've been running the 2.890 in an sd setup for quite a while on two different cars. I've installed & tuned 3 (one with just low rpm tune) using 2.8xx on a sd setup.
Never messed with quarterhorse & have only watched someone tune with a tweecer
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
50, anderson, base, curve, horse, learning, moates, pms, quarter, quarterhorse, rt, sale, tuning, turbo, tweecer, tweecerrt
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
