Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 02:46 PM   #11
19stang88
19stang88's Avatar
Vehicle: 1988, ford, GT
Quote:
Originally Posted by OnyxCobra View Post
you could easily run more than that depending on the setup and the tune. Imo only running 5-6psi of boost isn't even worth the price for the supercharger and supporting mods.
I am just trying to accomplish 300HP by supercharging. i can see how 5-6psi is not work it, is there other ways i can reach 300Hp?
19stang88 is offline   Reply With Quote
Old 10-05-2009, 03:06 PM   #12
1ATony
Sponsor
1ATony's Avatar
Vehicle: 92 Ford Mustang
Quote:
Not that it's not worth it,you'll get used to it fast and wish you had more.Save up for the 8-10 PSI Vortech kit, it'll come with the T-Rex in line pump, FMU, boost retard box,everything you need to install it.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Our Our Ford Mustang Parts
1ATony is offline   Reply With Quote
Old 10-05-2009, 05:37 PM   #13
Everyones Hero
Vehicle: 1986, Ford, Mustang GT
When I had a turbo'd civic the only things I had to upgrade on the car were the injectors & went with an EMS instead of a FMU (unless you guys are referring to the computer as the FMU & not a FPR or other hack device.) Also picked up a wideband, but you won't need that unless you plan on tuning it yourself.
Crome (the EMS I used) allowed me to change the amount of fuel dumped depending on boost & RPM. Same thing with the ignition. No need for FMUs or things like that. Also had other goodies like a 2 step & ignition retard based on boost levels.
Something that's not being considered is that you guys are saying 6-8lbs is the limit, but what are the HP limits? 6-8lbs on a small blower isn't going to make nearly as much power or move nearly as much air as a larger blower.
6lbs on something like GT17 sized turbo isn't going to make as much power or use as much fuel as 6lbs on a GT35 sized turbo.
I was running 12-14lbs but it was a small turbo so I was only making a little more than 100hp over stock.
Everyones Hero is offline   Reply With Quote
Old 10-05-2009, 07:23 PM   #14
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
When I first put mine on, completely stock, 9psi, intercooled I dyno'd at 303 to the wheels.
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 10-06-2009, 02:39 AM   #15
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
FMU is a Fuel Management Unit...I would sell the one that came with my kit for 50 bucks. That is why it is the bare minimum because it is so cheap...you can't make 19lb. injectors deliver enough fuel with any tuning device anyways with 6 psi without leaning the car out. However a fmu will work with 19lb injectors and cost less than going any other route.
TrimDrip is online now   Reply With Quote
Old 10-06-2009, 04:35 PM   #16
1ATony
Sponsor
1ATony's Avatar
Quote:
This is how mine is set up....for now anyway.
__________________
Tony
1A Auto Parts
1-866-403-3393
Old 10-06-2009, 04:54 PM   #17
Everyones Hero
Thanks. I'm still new to the mustang world, including tuning.
It cost me about $15 for my chipset & about $120 for my data logger & chip burner when I did my civic.
50, fine, mustang, stock, supercharge, supercharging
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
