Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 02:05 AM   #11
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
the reason it's getting worse is because with the pedal pushed in, the driveline is now only spinning from the inertia of the rear wheels. with the clutch engaged(pedal UP), the entire driveline is now under pressure from the motor, reducing any vibration because there is active torque in the line.
think of spinning a basketball on your finger. as long as you keep it going with your other hand, it will continue to spin fast and smooth. once it begins to slow and you're no longer applying continued speed to it, it wobbles and dances around.
__________________
mattdel is offline   Reply With Quote
Old 10-05-2009, 05:27 PM   #12
94mustang94
Vehicle: 1994 ford mustang
any suggestions to what it might be. and why it just now statred this the tranny and rear have been done for months
94mustang94 is offline   Reply With Quote
Old 10-05-2009, 07:12 PM   #13
mattdel
mattdel's Avatar
Vehicle: 1986 LX
tailshaft bushing from not properly addressing the length of the driveshaft issue with installing a 3550 transmission. they make the spacer for a reason.
__________________
Old 10-05-2009, 09:37 PM   #14
94mustang94
how likely is it that the tailshaft busing went bad. is this common for 3550s?
Old 10-05-2009, 09:46 PM   #15
mattdel
mattdel's Avatar
Vehicle: 1986 LX
its common in any transmission where the slip yoke is barely hanging onto the splines.
__________________
Old 10-05-2009, 09:51 PM   #16
94mustang94
well its only 5/8ths of an inch so there is still a fair amount in the tailshaft but i guess that 5/8ths really makes a difference?
Old 10-05-2009, 10:53 PM   #17
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
yes.. it does.
thats why the spacer exists
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-05-2009, 10:55 PM   #18
94mustang94
i was told by the guy that i got the tranny from said if i wasn't running to strong of a gear like 4.30's or more i would be ok w/o the spacer but it seems thats not true
Old 10-06-2009, 01:04 PM   #19
Jfsram
Vehicle: 93 Mustang LX
The driveshaft balance must be better than perfect for a steep gear like 4.30's.
__________________
65 Belevedere
69 Super Bee
87 Ram
93 Mustang
00 Park Avenue
http://www.cardomain.com/ride/754650
Jfsram is offline   Reply With Quote
Old 10-09-2009, 10:54 PM   #20
94mustang94
tailshaft busing good, spacer installed and i drove it around for like 10 min with no problems. i thought the vibration was gone and then it came back. this is crazy any suggestions
3550, tremec, vibration
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
