ok this post is for a buddy of mine. we pulled both of our plugs and both are white. although his codes are 34, 41, 91...could the faulty egr make his car run lean?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
if the egr valve is stuck partially open then it 'd cause a lean misfire but it'd be evident by a rough idle, swap o2 sensors side to side and if code goes to other side = defective o2 sensor, LUK
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
the idle seemed fine, but he just cleaned all the gunk out of the egr valve and put it back on. and now the idle is low and rough and cuts out sometimes...? bad egr?
semi related, but i removed all of my emissions crap and smog pump, gas mileage is about 160mi/tank. will that dummy egr thing on ebay do anything to counteract this issue, or just get rid of the code?
__________________
88GT Hurst Shifter Handle & Plate, Pro 5.0 Short Throw Shifter, Ford Racing Aluminum Drive Shaft, BBK UD Pulleys, BBK 75mm Throttle Body and EGR Spacer, BBK CAI, BBK Ceramic LT Headers, BBK OR H-Pipe, SLP Catback Exhaust
