i have a 95 auto 5.0 h.o. i recently just pulled out my original transmission because it started slipping. so i put another transmission in that was out of another car that a guy was doing a t5 swap. i was told the trans was good but it also slips in prety much the same exact way. i got all different sensors and a different torque converter when i put the new trans in. i thought it was ironic both trans were have the same exact problem of all 4 gears slipping... could it be anything other than the trans or do i just have 2 bad transmissions with the same exact problem...
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
You have two bad transmissions. IDK why you would buy another one that the owner told you was slipping. I'd take it out and look for another transmission. The AODE transmissions are fairly good transmissions when taken care of properly. When you get a new one, I would strongly recommend you buy a shift kit and a transmission cooler to prolong the trans' life. A rule of thumb: Heat is the #1 cause of transmission failure.
__________________
95 Mustang GT
TrickFlow H/C/I + AODE + Vortech SQ@16psi + Tweecer Tuned by Fritz Kloss
New Dyno #'s: 396rwhp/431rwtq(ran out of fuel)
New ET: 7.57@91 (1.84 60ft) http://www.youtube.com/watch?v=el5XYPGj4sM&feature
DD: 95 Mustang GTS- 5 spd; 306ci, Magnaflow X, Summit headers, Pypes Cat-back, K&N, MGW shifter
New ET: 9.7@72(2.34 60ft)
one more question.... why does the transmission tend to catch sometimes with no slipping at all. sometimes when you take off it will just fly. i dont get it.
does it have enough fluid in it?
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
