How to? I mean I got all my pullys and oil pan timing chain cover off - I got an 88lx that had a slight knock from main bearing or rod bearings so I took it out flippd it upside down an found some pretty copper / warn main bearings so Ima go ahead and buy a new crank that comes with main an rod bearings SO..i need to take my crank out and my only issue really is taking the timingchain off ...do i need to use a harmonicB / steering wheel puller tool? or ...? I appreciate the input
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
so what my cars 4 different colors
Yes, you need to use harmonic balancer puller to remove the balancer and then just take the bolt off the cam and it should pretty near fall apart then.....
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
