My neighbor's got the whole kit, wheel, dial indicator the works. Hes never used it though, he has all his motors built by somebody. Im not sure about any of the methods, is there a good link somewhere, or could you explain it to me.
btw mike, i got the springs, locks and retainers today. Everything looks perfect thanks
__________________
F**K THAT FUEL INJECTION S**
88' GT - GT40P's, Comp 986 vavle springs, Comp xe276hr cam, Comp Magnum 1.7 roller rockers, Comp Pushrods, Edelbrock 289 Performer 4bbl intake, Holley 650, BBK Longtubes, BBK shorty o/r H-Pipe, Dumped flowmasters, Ford 9mm wires, Crane PS91 coil, MSD 6A, Ford Racing 4.10 gears, Ford Racing King Cobra clutch, Hurst shifter, Holley Blue Fuel pump, jegs 12 gallon pro-street fuel cell, Holley Regulator, blood sweat and tears
first to be accurate, you'll need to verify TDC..........ANYWAY...well since the card gives you valve events at .006, my custom cams have come with .050 specs but I assume it'd be the same way, what I do is hot glue a washer to the top of a lifter and stick it in either the intake or exhaust bore in number 1 cyl THEN set up the dial indicator on the block in a solid place that'll allow you to put the dial indicator on the lifter top so that it rides on the washer you glued on, then, roll the motor over until dial indicator hits the .006 spec, if you verified tdc properly and wheel and pointer are mounted correctly, then when you hit spec on dial indicator the pointer on the degree wheel should be in line with what open spec says, if not retard or advance cam accordingly, but I verify both opening and closing on both intake and exhaust more than once to make sure it's on the money, verifying tdc is important or all will be off!!
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
