Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-09-2009, 12:26 AM   #1
motorman524
MF Informant
2008 Ford Focus
My Garage
motorman524's Avatar
Vehicle: 1987 Ford Mustang
Default misfire
So I've been replacing some old parts that prove to be inadequate as we continue to smooth out some rough patches trying to make everything right on the car. So far I've had to replace the shift cable because it kept slipping off the shifter and it was very hard to shift, the throttle cable because it wasn't opening all the way at wide open throttle and the coil because it was sleepy to say the least. Two or so days after I replaced the coil, the car starts to misfire when you try accelerating quickly, it doesn't have to be anywhere near wide open. when I bring it back in to check it out I see that my upper intake is cracked near the front where the shorter bolt is bolted into the lower intake. eventually it cracked all the way through and is now completely separate from the intake. I just ordered another upper but I was wondering why this happened? did I over torque it? is this my misfire while accelerating? My dad said it sounded like an ignition misfire. My last question is what is a hydrocarbon misfire?
__________________
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax
motorman524 is offline   Reply With Quote
Old 10-09-2009, 12:34 AM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
check to see if there is a vaccum leak there, as for why it cracked, over torque?? is the lower surface true???
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-09-2009, 12:41 AM   #3
motorman524
MF Informant
2008 Ford Focus
My Garage
yeah it completely broke off and there was a vaccum leak. I have a 1 inch spacer between my upper and lower, gaskets are new, intakes are clean. are those "high performance" spark plugs worth anything? maybe I need to upgrade something else in my ignition system?
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 10-09-2009, 01:04 AM   #4
STROKED_LX
Vehicle: 89 Notch 5.0
If the last thing you installed was coil before the misfire started, i would go back to your old coil and see if its ok, but first get that upper intake sorted out.
__________________
89 Notch 5.0
STROKED_LX is offline   Reply With Quote
Old 10-11-2009, 06:24 PM   #5
motorman524
MF Informant
2008 Ford Focus
My Garage
Ok I found the problem, The spark plug wire boot was cut causing the spark to arc to the header. Is there any type of spark plug wire or boot that you can buy to work with headers?
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 10-11-2009, 09:34 PM   #6
lxman1
Vehicle: 1988 Ford LX hatch
Are yours shortie or equal length? My MAC's are shorties and the 45* boots on the Accel fit fine. AutoZone brand fit fine as well.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 10-12-2009, 04:38 AM   #7
motorman524
MF Informant
2008 Ford Focus
My Garage
They are unequal length headers. The plug boot on #4 is the one that was cut. I think it happened when we were bolting the headers to the head. You have to put the plug wires on first then the heads or you can't get them on. Anyway, #4 was pushed up against the header really hard so we had to take the header back off. I used a punch to dent an area on the header so we could bolt it on. I noticed that the boot is starting to melt now too. Has anyone else had this problem and what can I do to fix it?
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 10-13-2009, 08:43 PM   #8
motorman524
MF Informant
2008 Ford Focus
My Garage
Has anyone ever had this problem? (read last post)
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 10-13-2009, 09:37 PM   #9
zebo87
Vehicle: 87gt
ive heard of people doing that also. making a little room for that wire.
__________________
Crate engine, b-303, cobra intake, cai, 3.73, 75mm tb & maf.
zebo87 is offline   Reply With Quote
Old 10-14-2009, 06:14 PM   #10
lxman1
Put a 90 degree end on that wire instead of the 45*.
I had one that melted back on #4 once and I wrapped the boot in rubber wire splicing tape and had no more issues with it.
Also, if you are running a colder spark plug, it will be longer and cause clearance issues. This was my problem when I ran N.O.S. on mine. The stock plugs don't cause it to hit.
__________________
1988 5.0 T5 LX HB
Oxford white
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
3rd, 50, 89, 95, accelerating, car, engine, ford, gt, misfire, misfires, misfiring, missfire, mustang, sn95
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
