Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-11-2009, 04:27 PM   #1
skidoorider
skidoorider's Avatar
Vehicle: 1986,Ford, Mustang GT Convertible
Question Engine idle "hunts" and stalls............
I recently picked up an 86 GT, 5.0 w/od automatic. When bringing the car to a stop, the idle speed "hunts" and eventually stalls. Sometimes, if I quick shift to neutral I can keep it running. I have not had the opportunity to change the fuel filter yet, however I am not sold that the filter would be the problem as the situation does not happen all the time. There are times when the motor idles fine.
Any ideas??
Thanks,
RB
skidoorider is offline   Reply With Quote
Old 10-11-2009, 06:15 PM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
remove the IAC valve, clean it out REALLY good, and check for vac leaks
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-11-2009, 06:35 PM   #3
9165pt0
just had the same situation...check for vac leaks and clean iac like adder said. you might also want to clean out the egr valve and go ahead and get the new fuel filter and check timing.
9165pt0 is offline   Reply With Quote
Old 10-11-2009, 09:26 PM   #4
lxman1
Vehicle: 1988 Ford LX hatch
Also check the EGR valve. If it is stuck open a little from carbon build-up, it will do that also.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 10-13-2009, 08:31 PM   #5
yyyktk1
Try disconnecting the battery. The computer will reset itself.
__________________
1989 Mustang LX 5.0: 17" Cobra R w/255/40's
GT40 Aluminum Heads, Crane 2031 Cam
FMS 1.7 roller rockers, BBK Long Tube Headers
FMS Aluminum Drive Shaft w/loop
Cobra intake upper and lower w/24# injectors
70mm BBK Throttle body & 75mm ProM mass meter
190 lph Walbro fuel pump, King Cobra clutch
FMS 3.55 rear gears with Auburn differential
yyyktk1 is offline   Reply With Quote
Old 10-18-2009, 04:29 AM   #6
gthokiwi
1986 Ford Mustang
gthokiwi's Avatar
Vehicle: 1986, Ford, Mustang GTHO
what is the IAC valve?
i have the same problem with my 86 gt. i have removed the EGR valve and sealed off the hole. im thinking the next thing for me to do is remove the manifolds and replace the gaskets.
gthokiwi is offline   Reply With Quote
Old 10-18-2009, 04:58 AM   #7
StangCatcher
Vehicle: 96 Mustang GT
The IAC is the idle air control valve. It is located on the throttle body, looks like a cylinder, two bolts hold it to the TB, and it has one connector on it.
StangCatcher is offline   Reply With Quote
2006, 50, 96, car, engine, forums, gear, gt, hunts, idle, idling, lx, mustang, speed, stalls
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
