Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-13-2009, 01:09 AM   #1
pony831
pony831's Avatar
Default x cam
Well im going to be converting to MAF this weekend. I'm also going to be putting in a edelbrock intake manifold. I currently have a F303 cam laying around, but my friend sells me a X303 cam for $100. Im going to drop in a cam since i'm putting the intake on. Should i put the F or X?
pony831 is offline   Reply With Quote
Old 10-13-2009, 09:42 AM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
better have springs matched to the cam and set up on heads with proper seat pressure, it's not as simple as slap the heads in and go or even that "I quote un quote have springs good up to XXX lift already"
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 10-14-2009, 02:43 AM   #3
pony831
pony831's Avatar
Ok the X cam is out, since I'm going to need to fly cut the pistons...so now im down between the B or F cam... i know the B is for low end torque and it says high rpm hp...and the F for mid-top rang. Which cam (between the B & f cam) would better match my edelbrock rpm manifold??
Old 10-14-2009, 08:58 AM   #4
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you still need to upgrade the valvetrain for either cam but f-cam or b-cam shouldn't need to flycut
__________________
Old 10-14-2009, 09:37 AM   #5
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
both cams suck ass. no sense in upgrade your valve train, wasting all that money and then having to buy another cam later because you are disapointed at its performance. trust me, you'll hate the b cam.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 10-14-2009, 01:18 PM   #6
pony831
pony831's Avatar
Quote:
How about the F cam? or what cam would u suggest? my setup is going to gt40 ported heads, edelbrock rpm manifold not i need the cam.
Old 10-14-2009, 01:32 PM   #7
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
trick flow stage 2 cam. $165 new.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 10-14-2009, 02:27 PM   #8
FivePointOhh
comp cams. xtreme energy is a great line of cams
__________________
Old 10-14-2009, 06:07 PM   #9
lxman1
Vehicle: 1988 Ford LX hatch
The new motor that I am buying which is a 96 Explorer 5.0 that was checked and freshened up has a set of ported GT40's on it and it runs strong with the TrickFlow Stage 1 cam in it. It sounds almost identical to my E-303 that's in my car now but makes more power.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 10-14-2009, 09:33 PM   #10
fordboy5.0
Vehicle: 1990 ford mustanglx
i would recomend the f-cam if your looking more for performance rather than gas mileage and drive ability if you have an auto you might have to get a stall converter but the f-cam is for more of high rpm horsepower you might also have to worry about piston to valve clearence with its .512 lift but any of the ford racing cams make good horsepower i think you would be pleased with it if its just going to be a street car you might also want to look into the e-303 its a good cam for street use and has better drive ability has no valve overlap (better gas mileage) and makes good horse power and would go good with your edelbrock intake.
fordboy5.0 is offline   Reply With Quote
302, 50, block, cam, cut, fly, ford, gas, good, idea, mileage, mustang, pistons, sale, stock, xcam
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
