Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-13-2009, 11:09 AM   #1
urban_cowboy
1969 Ford Mustang
urban_cowboy's Avatar
Vehicle: '69 Mustang Mach1
Default Crankcase Evac Pump
Are any of you turbo or blower guys running crankcase evac pump systems? I have a NA 383W in the 550-600ft*lbs range that is driving me nuts with crankcase pressure over 6000. I know this is a classic, but no one on that forum plays with street motors like this. I have run EGRs, breathers, header evac bungs. They all do about the same. I get some oil spray at high rpm and seal leakage when I spin it up. It is fine under normal cruise levels, but who drives all day like that . I want to throw in the towel and go with a vacuum pump and canister, but do not know what pump will last on the street. I run this car about 150 miles at a time and put 3-4k miles on it a year.
What have you run? What lasted?
Thanks a bunch for any help you can give.
__________________
"Yeah, were runnin a little bit hot tonight. I can barely see the road from the heat comin' off of it." Van Halen
urban_cowboy is offline   Reply With Quote
Old 10-14-2009, 08:59 AM   #2
urban_cowboy
1969 Ford Mustang
I found some info on an electric Ford pump, but it does not like to see oil, which seems worthless to me. I tried to call Moroso to get some idea of service interval on their vacuum pumps, but could never get in contact with someone.
Any ideas are welcome.
__________________
Old 10-16-2009, 02:39 PM   #3
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
How small are your lines/ valve cover port right now? I would definitely recommend the catch can. Probably not the vacuum pump though.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 10-16-2009, 02:52 PM   #4
luckythirteen13
luckythirteen13's Avatar
i run a header evac kit on mine. uses exhaust pulses to pull pressure out of the crankcase. i had a small oil leak at the rear main before i put it on, hasnt dripped a single drop of oil since
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 10-20-2009, 02:35 PM   #5
urban_cowboy
1969 Ford Mustang
I am running AN-12 line from the valve covers to the evac bungs. Even with the one way valves, there is very little suction on the lines. I thought about the catch can route, but that does very little to help the oil vapor from pushing out other places. Thus my thoughts on a vacuum pump.
__________________
Old 10-20-2009, 03:31 PM   #6
67mustang302
Vehicle: 67 Mustang Coupe
Quote:
If you look at a lot of the high power drag cars, like A and AA gassers as well as the larger fuel cars(so we're talking about 1,500-8,000hp cars) that's how they all do it. And if anyone would have trouble with crankcase pressure, they would.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 10-20-2009, 03:58 PM   #7
dukeme
dukeme's Avatar
Vehicle: 1993 LX Notch
Send a message via AIM to dukeme
Here is my set up
__________________
93Mustang LX 393 Stoker
Viper T-56 l Victor Jr. Aluminum Heads l Custom Grind Cam l 1.6 Scorpion RR l Vortec S1 l 373
http://s118.photobucket.com/albums/o...t=IMG_0081.flv
dukeme is offline   Reply With Quote
Old 10-20-2009, 06:08 PM   #8
urban_cowboy
1969 Ford Mustang
Quote:
True, but those guys are running open headers or straight pipe which does not create any back pressure. The velocity of the exhaust causes a vacuum on the bung. Along with crankcase pressure, this forces the oily gas into the exhaust pipe. I have a big free flowing exhaust, but since I have to run mufflers to be street legal it still has some back pressure. In speaking with Moroso, they said that is why header evac systems do not work well with muffler exhaust...back pressure kills the suction on the bung.
__________________
Old 10-20-2009, 08:33 PM   #9
67mustang302
There are a bunch of guys running header evac systems on the street without issue. You'd have to either install the fitting incorrectly, or have a ridiculously restrictive exhaust.
http://www.gzmotorsports.com/street-pump-kits.html This is the way to do it, but you're spending a lot of money doing it.
__________________
Old 10-21-2009, 12:53 AM   #10
FoxGT
Vehicle: unicycle
What happens when you run the valve covers without the one way valve or exhaust bung? The reason for the vacuum isn't to help pull it out at wot, it's to help ventilate while under cruise conditions. Your backpressure should be very low at cruise rpm & that's the only situation where you need the vacuum. Why do you have both valve covers going to evac bungs with one way valves? I would try running one with an evac setup & one open to air.
Just curious, where is the oil coming out of?
__________________
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
46, crankcase, electric, evac, ford, gz, install, kit, modular, motor, mustang, pump, street, supercharger, vacuum
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
