Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-17-2009, 05:53 AM   #1
9165pt0
Default gt40 intake spacer ?
hey guys do u know if a 1inch gt40 intake spacer will fit under a stock hood? and what are the benefits of using a spacer, do they actually help power? will i need a intake gasket on each side of spacer? thanks
9165pt0 is offline   Reply With Quote
Old 10-17-2009, 07:57 AM   #2
eddie_kawasaki
Vehicle: 1985, Ford, Mustang
I dont know if it will fit under the stock hood. Could you lay something on top of the intake an inch thick and close the hood to see if it will touch? Also,, dont forget that unless you have solid motor mounts the engine will rock side to side under accel and decel conditions, so if it clears just sitting there it may still touch when you accel or decel.
Spacers are supposed to keep the upper intake cooler by preventing some heat transfer from the lower intake.
eddie_kawasaki is offline   Reply With Quote
Old 10-17-2009, 09:21 AM   #3
Bubba 95SN
Vehicle: 1995 Ford Mustang GT
Modeling clay available at Wally World and can slam the hood if you want and not hurt a thing.
Bubba 95SN is offline   Reply With Quote
Old 10-17-2009, 10:56 AM   #4
Noblewk
Vehicle: 1990 Mustang gt Convert
Quote:
the quick answer is no. I'm working the issue right now on a 90 Gt. The Evac tube on the throttle body hits the hood. I'll know more today but I'm think it is actually hitting one of the hood braces, it that is the case a Hole saw should take care of that. If I didn't have to smog the car I would just cut it off and plug it.
Yes there are 2 gaskets (1 top/1 Bottom). You will need to get longer bolts also, the FRPP M-9486-A53 kit came with bolts but all were 1" short" so the local Hardware store supplied ones that would work.
Noblewk is offline   Reply With Quote
Old 10-17-2009, 10:23 PM   #5
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
nope won't fit, i have such and have a cowl hood so it'll clear on my 89
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-18-2009, 03:43 AM   #6
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
I run one on mine. I have two dents in the hood from it. One from the evac tube, one from the very front bolt on the intake manifold.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
convertible, fit, gaskets, gt40, hood, intake, intakespacer, manifold, mustang, pics, spacer, stock
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
