Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-18-2009, 04:25 AM   #1
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
Default Chip to tune 93 Cobra MAF, or aftermarket MAF???
Well on the dyno it showed the Cobra Maf was making my A/F ratio fat.
A guy over at modded mustangs says he can burn me a chip for $180 to tune the 1993 Cobra maf for the 24lb injectors that are waiting to be installed, and to even out the air/fuel.
Or i can buy a aftermarket MAF for $220-250 that is already calibrated for 24lb injectors, and most aftermarket one's arnt like the Cobra maf that has that huge obstruction in the middle of the air flow, and aftermarket MAF's are normaly CNC machined, so flow air better through the housing.
I'm basically hoping to avoid a custom tune with the mod's in my Sig, (including the heads and cam that will be installed very soon.)
So what do you guys think?
try the chip from the guy (has a good reputation doing this) Or get a aftermarket MAF?
(more then likely a BBK 76mm calibrated for 24lb's and CAI)
thanks for any input.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 10-18-2009, 04:33 AM   #2
302army187
1989 Ford Mustang
302army187's Avatar
Also C&L's 76mm maf for 24lb injector's is only $160......
http://www.americanmuscle.com/cnl-76maf-24lb.html
So IDK if it works great....... but the price looks good for the same set up (76mm, 24lb injectors) from BBK is $220
__________________
Old 10-18-2009, 02:45 PM   #3
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
buy the moates Quarterhorse and do it yourself. You are going to need a new tune after you do the h/c/i anyway.... might as well just spend the $250 and learn how to do it yourself
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-19-2009, 04:37 AM   #4
302army187
1989 Ford Mustang
302army187's Avatar
Is it really that easy or what?
I have no idea how to tune, and dont really wanna have the car sit for a month while I work out bugs, or blow the motor because I didn't tune it right..... total newbie to that junk.
btw, don't sell the cobra.
__________________
1993, 89, 93, aftermarket, air, airflow, chip, chipped, cobra, ford, housing, maf, mass, meter, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
