Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-24-2009, 05:25 AM   #21
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
I cant add to much to this.
Other then my car's oil pressue has been doing the same thing for over six month's and i beat the snot out of my car with no issue.
Im going of the stock gauge though.
I have a autometer oil pressure and temp gauge sitting waiting for install, just been to lazy!
good luck.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 10-24-2009, 12:06 PM   #22
88GTBLACK
Vehicle: 1988 Ford Mustang GT
Quote:
Originally Posted by 93 LX FiveO View Post
put a mechanical gauge on it like already mentioned.
my last mustang had less than 20psi at idle and ran consistent 14.1's in the 1/4 mile with few bolt-ons... AOD car to boot
lucas oil stabilizer will increase idle pressure by filling in the clearances in the bottom-end of the motor.
+1 I did that with a Mobil 1 oil change. I had an 87 and took a chance since the car was borderline parts car and pulled the drainplug put a quart of motor flush and filled the engine crank case with ATF and started the car until it warmed up. Drained the oil again new filter Mobil 1 synthetic and lucas oil stabilizer and the gauge always stayed in the center since dropped 1/4 the way down from low at idle. Leaked more oil but it worked.
I wouldnt recomend doing that, you can chance clogging the oil pickup screen if its not already I would first remove the sending unit and plug in a oil pressure tester to the sending unit I just did a 351W pickup at work and the sending unit was on the block by the oil filter might be the same idk. I used a mechanical gauge. Let us know what happens
88GTBLACK is offline   Reply With Quote
Old 10-24-2009, 01:52 PM   #23
Back-in-Black
1989 Ford Mustang
Vehicle: 1989 Ford Mustang GT Vert.
I got the Lucas oil stabilizer and it did not help. Still goes down to 10 psi after driving for awhile. Pan is coming down in the morning and putting in new oil pump. I am praying for good results!
Back-in-Black is offline   Reply With Quote
Old 10-24-2009, 04:30 PM   #24
AYEOH5.0
bad bearings, could be a problem.
__________________
1989 Mustang GT - 347 stroker
AYEOH5.0 is offline   Reply With Quote
Old 10-24-2009, 05:41 PM   #25
Back-in-Black
1989 Ford Mustang
Quote:
I thought about that and if replacing the oil pump does not work I am most likely just going to sell the car. I do not have the money to do an engine rebuild at this time.
Old 10-25-2009, 08:10 AM   #26
timspony
SVT Section Moderator
timspony's Avatar
Vehicle: 03 & 04 SVT Cobra
Quote:
Good luck!! Make sure you clean the baffle & pan well!
__________________
2003 SVT Cobra, DSG #7248 of 8394, Bassani Catted X, Flowmasters, JLT CAI, 2.76 BF Pulley, AFCO HE, PFab Tanks, SCT Xcal2, Pro 5.0, BF IRS Brace, Nitto 315 DR's...465 rwhp, 456 rwtq - Tuned by Mustang Magic!
2004 SVT Cobra, TR #269 of 1896 RagTop...Not Stock!
timspony is offline   Reply With Quote
Old 10-25-2009, 11:13 AM   #27
302army187
1989 Ford Mustang
302army187's Avatar
bearing's and a oil pump are not that expensive, or that hard to do yourself.
__________________
Old 10-26-2009, 03:24 PM   #28
Back-in-Black
1989 Ford Mustang
Not good news for my 89 vert. replaced the oil pump and still only getting 10 psi's at idle after running for about 30 minutes. I think I will be putting the car up for sale. I need a more dependable daily driver. Thanks all for your help. don't worry thou. I will not let you all get rid of me that easy. I will be back with a new to me stang in the near future!
Old 10-26-2009, 04:44 PM   #29
timspony
timspony's Avatar
Sorry to hear!!
__________________
Old 10-26-2009, 06:35 PM   #30
93 LX FiveO
1992 Ford Mustang
93 LX FiveO's Avatar
Vehicle: 92 LX 5.0
Send a message via AIM to 93 LX FiveO
why not just keep it? i drove my previous mustang everyday for 2 years and it would dip below 20 psi at idle sometimes. i also drag raced that car every week.. made over 200 passes the summer of '07.
you really worry too much.
__________________
new project website
93 LX FiveO is offline   Reply With Quote
1992, 351w, 50, cylinder, ford, gauge, guage, lucas, lx, mustang, oil, pressure, problems, stabilizer, upped
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
