Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-22-2009, 07:26 PM   #1
david2450
Vehicle: 1989, Ford, Mustang lx
Default temperture gauge not working
This is my first older car I guess you can say and I dont know much about it. Its a 89 lx 5 speed. An the temp gauge isnt working. I know its not the orginal gauge cluster that came with it. cause he said he changed it out because the needle broke on the mph.
david2450 is offline   Reply With Quote
Old 10-22-2009, 07:46 PM   #2
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
First things first. Check to make sure the gauge itself actually works and there are no problems with the wiring. You will find a 1 wire hookup sensor to the right of the distributor, this is the temp sending unit. Looks something like this.
Take the wire off of it, and ground the connector out somewhere with nice clean metal.
This, if all is well, will cause the gauge to go up to full hot, as far as it can go. Be sure the key is on.
If this does not happen, you have a bad wire, or a dead gauge.
If it DOES happen, you need to replace that sending unit.
__________________
mattdel is offline   Reply With Quote
Old 10-22-2009, 10:04 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
replace the sender and see if it works again
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-23-2009, 02:32 AM   #4
nacanitihs
Vehicle: 1989, Mustang GT
its called a temp switch fyi
http://www.autozone.com/autozone/cat...dName=Duralast
__________________
SVO GT40x Aluminum Heads, FRPP F303 Cam, GT40P Intake, 3.73s, Full Exhaust and Suspension
http://i56.photobucket.com/albums/g1...ynosheet-1.jpg
275rwhp and 300ftlbs
nacanitihs is offline   Reply With Quote
1989, 89, broken, gauge, gt, guage, mustang, read, sensor, temp, temperature, working
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
