Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 11:02 AM   #1
FrankenStangNPD
FrankenStangNPD's Avatar
Vehicle: '96 Mustang GT
Default swapping mt into auto 95 5.0
I am swapping a manual transmission into a friends 95 5.0 and need to get a complete list of all parts needed. This is what I think I need.
computer, pedal assy, transmission, clutch, bellhousing, clutch cable, transmission harness, shifter, console, flywheel.
will i need driveshaft, crossmember or anything else? will the same starter work? any help would be appreciated, we need to be sure we have every single part before we start the swap.
__________________
~Chris~
'96 GT with COMPLETE '03 GT conversion, BBK shorty headers, BBK X-Pipe, Flowmasters Turndowns, Cobra R Wheels, CAI, ECU Tune, B&M Precision Shifter.
1/8 mile time 9.29 @ 78 MPH
FrankenStangNPD is offline   Reply With Quote
Old 10-23-2009, 08:10 PM   #2
94StinkinLincoln
94StinkinLincoln's Avatar
Vehicle: 1995 mustang gt
Send a message via Yahoo to 94StinkinLincoln
t5 or tko?
the auto pcm can be used, the shifts need to be tuned out.
pedals, tranny, clutch, flywheel, bell, block plate/spacer plate (metal plate) they might be different for the sticks, i can measure my auto plate and my buddys t5 plate and let you know.
tranny harness, shifter, i think the console does not need to be swapped, i will find out soon myself.
you will need a throw out bearing, pilot bearing, and a clutch fork, clutch cable and firewall adjuster, and clutch quadrant.
the drive shaft should work, count the splines first, they could be different, but i dont think they are.
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
94StinkinLincoln is offline   Reply With Quote
95, ford, mustang, swap, transmission
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
