Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 02:02 PM   #1
macdaddy1989
1989 Ford Mustang
Vehicle: 89 GT, 07 Mazda 3, 05 GSX-600
Default high idle problem
i have and 89 gt that when cold has check engine light on and idles fine, but when warm check engine light goes off and idles at 2000rpm. i have already changed all vacc lines, new egr valve, egr position sensor, Throttle position sensor and IAC. also cleaned MAF 2 times with MAF cleaner. I have been told it could be the MAF, o2 sensors or the IAT( Intake Air Temp Sensor (AKA Air charge sensor)). Does anyone have any ideas??????
macdaddy1989 is offline   Reply With Quote
Old 10-23-2009, 02:57 PM   #2
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
If the MAF was bad beyond cleaning, it could cause it, but generally it wouldn't run right at any RPM either, so that's your call. o2's wont cause it, neither will IAT. The ECT will though(engine coolant temp), which is located to the left of the distributor near the #1 injector. This sensor would have to be giving really really wacked readings to do this, though. Check the tech articles for a sticky I wrote about running rich. The same test would apply to check to see if this sensor is the cause of the high idle. You'll be looking for readings that cause the computer to think the engine is extremely cold.
If that checks out ok, you're going to need to do a base idle reset procedure.
http://www.muscularmustangs.com/idlereset.php
__________________
mattdel is offline   Reply With Quote
Old 10-24-2009, 12:57 AM   #3
macdaddy1989
1989 Ford Mustang
thanks i am going to try that. ill let you know what happens. thanks again
Old 10-24-2009, 08:40 PM   #4
macdaddy1989
1989 Ford Mustang
it was the ECT. it also caused the car to not crank very well after it was warm. thanks. that saved me alot of money. i was about to buy a MAF and o2 sensors.
Old 10-24-2009, 10:38 PM   #5
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
next time try running a koer test and pulling codes, and that will save you alot of time
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-25-2009, 02:12 AM   #6
macdaddy1989
1989 Ford Mustang
can you explain to me what a KOER test is?? and since i change the ECT, do i have to check the voltage on the TPS as well.
02, 2000, 50, 89, engine, ford, high, idle, idles, mach1, mustang, problems, running, supercharger, warm
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
