17.1 at WOT or near redline (even crusing) is dangerous for an engine.
I was referring to under cruise conditions. If your final gear is at redline while cruising, then i don't suspect the engine would last long anyway. At near redline, low load is a condition where fuel economy isn't a main priority, all the same there still isn't enough air/fuel to cause temperatures to skyrocket. Running lean there isn't a big issue, the only case where it would be is if you have a very inefficient engine & it requires having the petal down quite a bit to maintain the rpm in which case it isn't a low load situation. I've usually pull around 18-20in. hg at high rpm, low load to maintain & i'm around 17-18 at idle.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
