Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 01:50 PM   #1
Tony71502
Tony71502's Avatar
Vehicle: 1991 Ford Mustang
Default Idle Fluctuation
When I start up the car at idle the rpm fluctuates almost to the point of stalling. This tends to go away after about 20-30 seconds. After that the idle fluctuation is about 50 rpm. There's no problem when the throttle is open even the smallest bit, not that I can tell.
Would this be as simple as a bad IAC? The IAC on there is only 2 years old and still clean.
Or could this be some tiny vacuum leak that almost fully closes as the engine warms up? 20-30 seconds doesnt seem like enough time to fully warm up from a cold start, though.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Tony71502 is offline   Reply With Quote
Old 11-03-2009, 08:44 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
make sure the throttle body is clean and the mass air meter is clean and no vaccum leaks
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-04-2009, 03:25 PM   #3
Tony71502
Tony71502's Avatar
Thanks Mike.
We cleaned out the MAF and IAC two days ago and that didn't help. I'll try cleaning the throttle body out. The TPS is fine. I sprayed a healthy dose of starting fluid around and there was no leaks. The only leak that I had was between the EGR spacer and the upper intake plenum. That's fixed.
The only codes in the computer are EGR and thermactor/thermastor related. No CEL is present. The codes are benign.
The car has power. Just the B cam in a stock block spins the 275's through second gear. Granted it was about 50 degrees out...
I'm going to grab a new IAC soon and see if that helps at all.
My intake system is 19 years old... I may just start upgrading.
__________________
1991 LX 5.0 5Spd
Tremec T5
MM Suspension
50, cold, fluctuation, fluctuations, idle, mustang, start, supercharger, throttle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
