Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 04:05 PM   #1
flight86
1986 Ford Mustang
Vehicle: 86 ford mustang
Default How to check the TPS
I need help on how to check my throttle position sensor.
flight86 is offline   Reply With Quote
Old 11-03-2009, 09:25 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
why?? and in what way do you wish to check it???
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 11-03-2009, 09:46 PM   #3
lil_hulk87gt
1987 Ford Mustang
Vehicle: 1987 ford mustang gt
Send a message via AIM to lil_hulk87gt
get your volt meter take the red wire off of t and stick it it to the green wire on the tps and ground the black one turn key on and look for .97 to .99
lil_hulk87gt is offline   Reply With Quote
Old 11-03-2009, 10:04 PM   #4
flight86
1986 Ford Mustang
Quote:
well I've been having some Idle problems. My idle surges from 800 rpm to 1100 rpm. Just wanted to rule out the TPS.
Old 11-03-2009, 11:41 PM   #5
mjr46
mjr46's Avatar
Vehicle: 85 mustang
try running a koeo/koer test, that'll tell you if any codes relate to such
__________________
Old 11-04-2009, 10:56 AM   #6
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
this got me thinking how ive NEVER checked mine.
I dont have ANY running issues at all, but when i checked mine it was at .85-.89
I just set it to .97-.98....... what could this change if anything?
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 11-08-2009, 01:56 PM   #7
smokedog
1990 Ford Mustang
Vehicle: 1990 Saleen Mustang
is the factory throttle body TPS non adjustable?
__________________
1990 Saleen #35 of 173 - 36,000 miles, 5 speed w/ short throw shifter, BBK cold air intake, MSD distribitor, smog delete, 3.55 gears, underdrive pulleys, BBK stainless steel headers, BBK offroad H-pipe and flowmaster catback exhaust.
smokedog is offline   Reply With Quote
Old 11-08-2009, 02:30 PM   #8
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
it is never good to set the TPS to .98 or .99 volts, often times the car will (when running) show a higher voltage than the ECM allows and the car will think its at part throttle.
The TPS should be set between .80v and .90v
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 11-08-2009, 07:27 PM   #9
302army187
1989 Ford Mustang
302army187's Avatar
everything ive seen always say's .99 with about 4v at WOT
__________________
Old 11-08-2009, 08:25 PM   #10
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Quote:
actually, the range is .7-1.0 volts. If your car, in the ON position is set to .99 volts, it will very often, at idle, be around 1.04-1.05v. Therefor putting your car into "part throttle" as far as the ECM is concerned, and can cause surging, stalling and other idle related issues.
__________________
302, 87, 98, adjustable, cars, check, cobra, density, ford, mustang, position, sensor, set, speed, throttle, tps
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
