well after a few months of abuse im leaking coolant from my intake. with the winter month coming up i plan on pulling the car off the road and doing some upgrades. i want to go with a single turbo but keep the stock block and possible make it a 306. i needed some pointers on what to fill the block with. since i wont b making nemore then 450 HP i dont know if i will need to have nething forged or if cast will work. i have a b303 cam, hardened pushrods, HV oil pump, and lifters that i would throw in and possibly a set of aluminum GT40 heads and intake. i would like to put that threw a tko 500/600 but i dont know which one is for me.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
with a stock block it'll all be a gamble, no need to use forged crank cause the block will let go long before crank, just get a set of forged I beam rods, cast steel crank and a decent set of dished forged pistons
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mind consulting me on a tko500 vs tko600? i know there is a 100lb- ft torque difference but other then that which one should i consider and y? for instance what should i consider when lookin at the spline difference between the 2 trans
I myself would go 600 to be safe and in case you ever wanna go bigger
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
That is why I went with my 600. I wanted to make sure I never had to buy another transmission again. I lucked out and bought one from a member on this site.
__________________
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax
