Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 11:12 AM   #11
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
we'll try it
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-06-2009, 11:41 AM   #12
primetime5.0
Vehicle: 88 GT
I know this sounds ghetto but I took my egr apart and just kept the part the the connect plugs into.. I glued the plunger down on the egr so the computer thinks its working.. There is a guy on corral who sells a nice egr simulator for cheap too
__________________
R.I.P. Robert H. Western
ported e7's and an e303 cam
primetime5.0 is offline   Reply With Quote
Old 11-06-2009, 11:47 AM   #13
motorman524
MF Informant
2008 Ford Focus
My Garage
motorman524's Avatar
Vehicle: 1987 Ford Mustang
I bought an egr eliminator and a delete plate from http://rjminjectiontech.com/?p=9
__________________
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax
motorman524 is offline   Reply With Quote
Old 11-06-2009, 04:39 PM   #14
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
I did the three resistor EGR delete.... it didnt work
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 11-06-2009, 05:51 PM   #15
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
attention whore.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 11-06-2009, 08:08 PM   #16
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
how did it work??? looks like a clean deal.
__________________
Old 11-08-2009, 12:45 PM   #17
lxman1
Vehicle: 1988 Ford LX hatch
I bought the 70mm delete plate. If you have a stock intake or Explorer intake, it moves the TB too close to the heater hose tubing and the linkage hits.
What I did recently was install the block-off plate, then the EGR plate and then the TB. I unhooked the hot coolant hoses and connected them together with a 4160 series Holley fuel transfer tube to keep the intake cool. I still have the EGR valve hooked up and it moves like normal so the sensor reads properly, but there is no actual EGR flow into the engine. No EGR codes.
Don't know if this will work for you since you have no vacuum going on.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 11-08-2009, 02:05 PM   #18
mjr46
mjr46's Avatar
Vehicle: 85 mustang
I have a cobra intake and egr plate blocking off holes on intake, heads are non emissions heads so they don't even have the exhaust crossover on them...ROGER that!!lol
__________________
Old 11-08-2009, 09:31 PM   #19
motorman524
MF Informant
2008 Ford Focus
My Garage
Quote:
Like LX, I had an issue with fitment. My throttle cable and kickdown cable bracket was up against my fuel pressure regulator though, not any hoses. I just marked the area that it was hitting and shaved what was needed to get it to work, wich wasn't much. I am running a stock fuel rail with a Kirban adjustible fuel pressure regulator and gt40 intakes with a 1inch TFS spacer. As far as the egr eleminator, works great, no light.
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 11-08-2009, 09:47 PM   #20
mjr46
mjr46's Avatar
Vehicle: 85 mustang
cool, did you run the car with the egr unplugged previously then buy this eliminator or did you just buy it then unhook all and install eliminator??^^^^^^^^^^^^^^^
__________________
1987, 31, 84, code, f150, ford
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
