So I have code 31 and 84 present in my 89, no fear I know why, I deleted egr and removed the vaccum regulator for the emissions, question is the CEL remains on for these codes = only ones present, I read about before the diode trio set up to address this issue, anyone have an article on the procedure and details on it's purpose??? thanks guys
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
yea mike, i have the 3 resistor thing on my egr plug to delete the CEL. i dont remember what resistance they are supposed to be right off hand but i can PM you the link to what i used here in a few. I have a client relations meeting here in a few so it may be a while before i can send it to you.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
so will that also get rid of the evr code, meaning since I don't have the vac regulator selonoid plugged in anymore will it cure that code too?? thanks kyle
__________________
yea it should. i ran codes right after i got my f'd up head back from the shop a month ago and came up all clear. i also have all emissions deleted.
**edit**
i'll revise that sentence. i had evr code originally when i started up the car. but after about an hour of use, i ran koeo/koer just to be sure that was all i got and it disappeared, so it may just calculate itself out after so much use. all i know as that it doesnt appear anymore.
(previous owner removed the check engine light so i have to run codes for now until i get that light bulb fixed.)
__________________
I've never heard of this if you do it mike lmk mines on because of the evap system
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
yea i dont know if it'll remove the light since mine doesnt work. i just know it doesnt appear when i pull codes. sorry i guess i wasnt a TON of help to your question, but thats how you bypass the egr code.
__________________
