Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-05-2009, 07:42 PM   #1
gregamuffin
Default popping noise, hesitation, maybe backfiring?
ok i searched first so dont flame me but it seems like there are two different kinds of popping being addressed, a misfire and a backfire.
my issue has gotten progressively worse over the course of the week. when i first start the car it idles ok and i can rev it no problems. however once under load it will pop a little and hesitate. these pops sound like theyre coming from the exhaust NOT the engine so this would be a backfire correct? usually after a couple of them it would go away and be a non issue either once the car warmed up or i was at a steady pace and then warmed up. however, tonight on my way home from school just a short trip it was popping and chugging badly and i could hardly get my speed up id let off down shift try and work my way up again and it was a nightmare. i guess tomorrow ill see how it went but i was wondering what would be causing this and how to fix it. its a 1990 5.0 lx. i was hoping to do a rebuild over the winter but that will rest upon if my parents will let me buy a winter beater. thanks for the help in advance.
gregamuffin is offline   Reply With Quote
Old 11-05-2009, 10:18 PM   #2
mustangsneverdie
1985 Ford Mustang
mustangsneverdie's Avatar
Vehicle: 1991 mustang
how long's it been since it had a tune up,timing could also be off check to make sure the distributor is tight
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
mustangsneverdie is offline   Reply With Quote
Old 11-05-2009, 10:58 PM   #3
gregamuffin
ive owned the car for about 3 months and have been so occupied with the other small things i havent done a full tune up yet. but i now i need to anyway so that will be in order and i will check the distributor any other suggestions? other than wanting to know just how to fix it i would like to know WHAT'S actually happening while this is going on and why? anyone know? thanks
Old 11-08-2009, 12:51 PM   #4
lxman1
Vehicle: 1988 Ford LX hatch
Could be a misfiring plug. Yes, plugs, wires, cap and rotor are always a good place to start.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 11-23-2009, 07:32 PM   #5
foxgt91
Vehicle: 1991, Ford, Musatng GT
gregamuffin,
Wondering if you were able to locate the problem? I'm having same issues...hesitation and a corresponding popping noise. I've change and checked several things with no luck.
foxgt91 is offline   Reply With Quote
Old 11-23-2009, 09:06 PM   #6
AntiRiceRacing
AntiRiceRacing's Avatar
Vehicle: 1984 Mustang Notchback
Send a message via AIM to AntiRiceRacing
Try plugs first for sure. Make sure you gap the new ones correctly too.
__________________
If you want it cheap and fast it won't be good.
If you want it cheap and good, it won't be fast.
If you want it good and fast, it won't be cheap!
84' notch
AntiRiceRacing is online now   Reply With Quote
Old 11-23-2009, 09:43 PM   #7
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
TRY A FULL TUNE UP AND CLEAN THE MAF AND MAKE SURE THE TIMING IS SET
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-24-2009, 12:27 AM   #8
gregamuffin
I bumped my timing to 14 and that seemed to do the trick. A full tune up is still in order but so far this has cured the 'morning sickness' popping. Good luck to the other guy with similar problems
Old 11-24-2009, 10:50 AM   #9
Tempted
Vehicle: 2081 Chevy Mustang
You may need to run 91 octane to prevent detonation at 14 advance. I think stock was 8 w/o the vacuum advance connected. Refresh my memory, is the 90 a vacuum or electrical advance? Either way, your problem could lie there.
Tempted is offline   Reply With Quote
Old 11-24-2009, 12:45 PM   #10
gregamuffin
Well I don't have a stock cam I thought the stock timing was 10 anyway? Either way 14 seemed to solve my problems
1985, 46, 50, backfire, backfiring, body, density, exhaust, ford, fox, hesitation, missfire, mustang, noise, popping, speed, supercharger
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
