Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 02:26 PM   #1
88GTBLACK
Vehicle: 1988 Ford Mustang GT
Default running rough...cant get it perfect
Heres the deal. I disconnect the MAP sensor it smokes at idle a whiteish smoke, hunting idle, but runs great at WOT. Plug in the MAP and it skips a beat at WOT between shifts idles at 800 alright.
I disconnect the IAC it dies. Timings been played with from 16-8 i set it back at 14. I just put the exhaust on. and I broke an O2 sensor. so i just filled in the exhaust holes with a plug and left the o2s out. But O2s dont get read until the engine is warmed up. it does this in closed loop mode too.
Now it ran perfect before i deleted the emissions and the a/c and started ripping out vacuum lines. Vacuum Line still goes to the MAP sensor.
Plugs wires all tune up stuff is brand new.
My guess its leaning out at WOT around 3 grand and on it will skip a beat.
But all vacuum lines are plugged? So that shouldnt cause it to run lean if thats even the problem.
88GT speed density.
__________________
Winter build in progress
need door speaker grills, black seatbelts,
TF stage1 cam, Timing Chain, complete a9L conversion
140mph cluster 87-89 Rear control arms
South-Central Jersey. PM Me
88GTBLACK is offline   Reply With Quote
Old 11-06-2009, 04:31 PM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
removing the EGR will cause a poor idle at initial start up, you need to also disable it electronically.
you really NEED to put the O2 sensors back in the car
until you fix these deficiencies, you cannot begin to troubleshoot any other problems
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 11-06-2009, 06:24 PM   #3
mustangsneverdie
1985 Ford Mustang
mustangsneverdie's Avatar
Vehicle: 1991 mustang
Are you taking anti-depressants???You seem a lot less hot-headed than you use to,at least that what I get from your last few posts
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
mustangsneverdie is offline   Reply With Quote
Old 11-06-2009, 07:59 PM   #4
88GTBLACK
Disabling emmissions eletronically...how would I go about disabling it?
o2 sensors are being ordered, are they different on a9L cars because im going to be swapping for mass air when I do my h/c/i.
__________________
Old 11-07-2009, 09:11 AM   #5
streetstang88gt
streetstang88gt's Avatar
Vehicle: 1988 mustang gt
you gotta put mass air on speed density with a cam! my first mistake and couldn't figure it out for like a year...haha...i did the mass air conversion and WALLAH!! fixed! no idleing issues! do that and it'll fix everything! I can almost guarantee you!
__________________
1988 Mustang GT- 302ci, GT40 tubular upper and lower, GT40P heads mild port & polish, 1.6rr, B303, BBK fenderwell c/a, 73mm C&L, BBK Longtubes, BBK o/r X, 40 series Flows, King Cobra clutch, Pro 5.0 shifter, 3:55 gears, eibach springs, KYB shocks and struts, etc...
www.cflponysports.com
streetstang88gt is offline   Reply With Quote
Old 11-07-2009, 12:48 PM   #6
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
look at my diode trio thread for egr
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-07-2009, 11:43 PM   #7
88 notch
Vehicle: 1988 coupe
vacuum line to the map sensor???
88 notch is offline   Reply With Quote
2000, 50, 88, ford, mustang, rough, running, runs, tune
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
