Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-07-2009, 11:41 PM   #1
NoGo95GT
1995 Ford Mustang
NoGo95GT's Avatar
Vehicle: 95 Mustang GT
Default Slipping clutch??
I cannot tell if my clutch is slipping? Last week I was on the freeway in 5th and needed to get past a semi. I gave it gas, and the car really did not move, then all of a sudden it did. It is really hard to explain. But the best analogy I could get is it is kind of like a VTEC(I guess). There's no power then all of a sudden it hits. It happens a lot, throughout all gears, but is also somewhat intermittent. I give it gas and the rpms move, but the car does not seem to have any power, then all of a sudden it does at a higer rpm, like maybe the clutch finally grabs. Thinking it was fuel related, I taped a fp gauge and drove around and it was fine. Fuel filter and 190lph pump are two moths old. Just for extra insurance I replaced my fpr(had an extra one). Thinking it was a hesitation I checked my ignition. Plugs and wires are two months old, swapped my coil and dizzy from my other Mustang to no avail. When I had the engine apart, I inspected my clutch. It had an awkward wear on one part of the disk, but it looked like it had been recently replaced(maybe 1-2 years old MAX) and had looked to be in decent shape. My dad's Acura's clutch currently has a slipping clutch and it feels completely different though. I was just curious as to what you guys think? Any help would be great! Thanks!
__________________
95 Mustang GT
TrickFlow H/C/I + AODE + Vortech SQ@16psi + Tweecer Tuned by Fritz Kloss
New Dyno #'s: 396rwhp/431rwtq(ran out of fuel)
New ET: 7.57@91 (1.84 60ft)
http://www.youtube.com/watch?v=el5XYPGj4sM&feature
DD: 95 Mustang GTS- 5 spd; 306ci, Magnaflow X, Summit headers, Pypes Cat-back, K&N, MGW shifter
New ET: 9.7@72(2.34 60ft)
NoGo95GT is offline   Reply With Quote
Old 11-08-2009, 12:36 PM   #2
projectresto83
projectresto83's Avatar
Vehicle: 83 GLX, 93 LX, 98 sixer
Sounds like the clutch could be the issue. Does the rpm's drop back down when the car starts pulling normal then go back up like nothing ever happend?
__________________
Off building sand castles in the middle east
projectresto83 is offline   Reply With Quote
Old 11-08-2009, 05:26 PM   #3
NoGo95GT
1995 Ford Mustang
NoGo95GT's Avatar
Not that I can tell of. But, the car eally acts up once the car has warmed up, possibly causing excessive heat on the clutch. But I'll pay more attention to what you said. Thanks!
__________________
95 Mustang GT
Old 11-08-2009, 06:38 PM   #4
AYEOH5.0
normally if your clutch is slipping, you can go in 4th or 5th and step on the gas and the rpm's will go up but the car wont go anywhere.
__________________
1989 Mustang GT - 347 stroker
AYEOH5.0 is offline   Reply With Quote
Old 11-08-2009, 07:53 PM   #5
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
yeah put it in 5th the car should stall if not its slipping
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is offline   Reply With Quote
Old 11-08-2009, 08:11 PM   #6
OnyxCobra
OnyxCobra's Avatar
Vehicle: '95 Mustang Cobra
Send a message via AIM to OnyxCobra
it doesn't sound like the clutch is slipping necessarily. If it was slipping when you stepped on the gas the RPM would go up but your car wouldn't really accelerate. then after a few your car would catch up to the PRM. Usually you can smell it burning if it's bad enough too.
__________________
CarDomain - OnyxCobra
OnyxCobra is online now   Reply With Quote
Old 11-08-2009, 10:08 PM   #7
NoGo95GT
1995 Ford Mustang
NoGo95GT's Avatar
Quote:
Yeah, basically what you are saying is kind of what is happening. I give it gas, the rpms go up somewhat normal, but the car moves slowly, then right around 3000rpm, the car regains speed. It's very prevalent from 1500rpm-3000rpm in second and fourth gear. I drove the car 50 miles today with 0 problems, so it's very intermittent( got on it maybe twice too).
__________________
95 Mustang GT
Old 11-09-2009, 01:22 PM   #8
OnyxCobra
OnyxCobra's Avatar
it should get progressively worse in the higher gears, it should slip the worst in 5th. I wouldn't think it would be intermittent though, should always happen.
__________________
Old 11-09-2009, 03:19 PM   #9
1ATony
Sponsor
1ATony's Avatar
Vehicle: 92 Ford Mustang
If you end up needing a clutch for your car, Exedy came out the other day to meet with us,we've been carring their clutchs for a while there pretty nice.
Here's a link to them on our site, if you would like to check them out.
Mustang Clutch Kit
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Our Our Ford Mustang Parts
1ATony is offline   Reply With Quote
1995, 1997, burnt, causing, clutch, cobra, ford, mustang, mustnag, slipping, smell
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
