I am looking to pick up a late 80's early 90's Mustang LX 5.0 Manual trans.
I am currently looking at buying an '88 to modify for possible SCCA racing. I have heard that there are some years to avoid because of fuel injection changes. SD to MAF? I had a first gen Lighning modified pretty heavily so I know what I want to do. I just want to be educated before getting into my first Stang.
Thank You for your help.
Skrappy
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2006 Vista Blue GT 5spd
Hurst Shifter, K&N, Kicker/Infinity/Sub, spkr, etc...
89-93 mustangs came with factory mass air as did 88-93 CA mustangs. Previous year mustangs had speed density EFI. Older mustangs also had carburation and some had something called CFI. I don't think there are really any stangs to avoid, but if you are gonna go all out with mods the 89-93 mass air's are better for mods. Also Ford stopped using forged pistons with the 92 model year. The 93's pistons are not as good for s/c, turbo, or n2o applications.
__________________
Paul
'95 White Cobra #241 of 4005
3.55 Gears, Steeda Sport Springs, MAC 2.5" O/R H-Pipe, Dynomax Ultra Flows 2.5", MAC Chrome CAI, Pro-M Chrome 75mm MAF, UPR C/C Plates
If u were to avoid one it would be the 86 year because that is when ford switched from carbs to EFI. The first year of anything new tends to have a few bugs that need to be worked out.
I have heard great things about the MAF system that comes stock on the 89-92 cars. I heard that it accepts modifications like new heads with good porting and a new intake pretty well. I am ultimately looking to keep it NA and go with some Head/Intake and Header/Exhaust combo. So it looks like I should stay in the '89-92' range to make it easier to modify unless I want to buy a new MAF kit for it.
Next question then:
How easy is it to retro fit a MAF on a '88 or newer, can I head down to the pick and pull, get a used one and slap it on? How much should I look to spend if I had to go this route? I am afraid that this '88 LX notchback may be too clean to pass on...
Thanks Again for your help!
Skrappy
__________________
Any fox can be really built the same. It's just that you start off with some different components at first.
86 was the first year for speed density sequential port fuel injection, 8.8 rear-end, H-pipe exhaust with double hump cross member, first year for quad shocks(not that great anyhow). 86 was also the only year with 9.2:1 compression due to flat top pistons which is bad because you can't add a cam or 1.7 rockers.
Also, any SD car can easily be converted to mass air flow. And if you're going to be serious about the project, you'll most likely be starting fresh with a new short block at least built to what you ultimately want.
So I'd say if you want to stay Fuel injected then get at least an 86 or newer.
I believe the quad shocks came out in 84. My 85 certainly has them. Also the 85 was the first year for forged pistons and roller cam.
I have to say I'm pretty happy with my 86. You are limited to what you can do but that can easily be fixed if you rebuild the block. I've been looking into a mass air swap since I got the car and it doesn't look like there is much too it at all.
__________________
84 Mustang SVO
86 Mustang GT
http://www.youtube.com/86zach
Skrappy
There used to be an all inclusive kit to convert SD to mass air. Don't know if its still available. If not I believe you need to pick up a pcm from a mass air car, the harness, sensors, and the mass air meter.
__________________
Paul
