New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-14-2005, 01:57 PM   #1
amhsraptor
My Garage
Default nitrous pressure and fuel pressure
ok, so i got a nitrous pressure reg and a fuel pressure reg; all i need to know is how to install it the guy we got the car from promised to send instructions-so much for that lol
__________________
'91 mustang gt convert 5.0 w/ some other stuff
"If we ever forget that we are one nation under God, than we will be a nation gone under."
http://www.cardomain.com/ride/2569441
amhsraptor is offline   Reply With Quote
Old 12-14-2005, 08:44 PM   #2
JD1969
Moderator
My Garage
JD1969's Avatar
Send a message via AIM to JD1969
Default RE: nitrous pressure and fuel pressure
The nitrous will not have a regulator in the way that your fuel system will, the temperature of the bottle will cause the pressure to go up or down, now you can get a bottle heater that will have a pressure sensor to tell it when to turn on and shut off. You want to stay between 900-1100 psi, this is the pressure that the companies calibrate the jets for.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
JD1969 is online now   Reply With Quote
Old 12-14-2005, 11:29 PM   #3
nitrous_bob
My Garage
nitrous_bob's Avatar
Vehicle: 1993 notch
if it's an NOS kit, the nitrous reg is the blue round looking thing , that is not a selonoid.
is there a kit on it? just look at the nos instructions for that...find it on http://www.holley.com and follow the links to NOS
the fuel press reg is behind the upper intake, 3 screws, then swap it out , there is a red(probably a red) vac line on the top of the fp reg.
and are you talking about the regs? or guages? just to make sure....
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
http://www.myspace.com/nitrous_bob
nitrous_bob is offline   Reply With Quote
Old 12-15-2005, 11:03 PM   #4
silver91gt
My Garage
the senders and the gauges need to be the same brand for them to work properly.
if you talking about the gauges then
the fuel pressure gauge if it is electrical will need a sender that taps into the schrader valve on the fuel rail. then wire it in.
if it is mechanical you cant hoook it inside the car.
you will have to put it on the hood or cowl or something.
for the nitrous gauge, the electrical is the same,
hook the sender somewhere between the bottle and solenoid, then wire it.
for a mechanical gauge you will need some nitrous line and a "t" fitting to tap to the nitrous line.
then route it safely to the gauge.
__________________
novi powered 347 11.6@121mph
with a little spray 10.7@130mph
silver91gt is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
