Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-25-2004, 11:27 PM   #1
mustang50
Default 331 vs. 347 stroker
I am planning on building a supercharged 331 or 347. The problem is, I don't know which one to get. This motor will be efi and in a daily driver car. I keep on hearing that 347's burn oil. Is this true? </P>
Which stroker kit should I get? 331 or 347?</P>
Thanks.</P>
__________________
mustang 50
mustang50 is offline   Reply With Quote
Old 01-25-2004, 11:33 PM   #2
619socalstang
dont know but more is better right when going for power right
__________________
IT IS NICE TO BE IMPORTANT, BUT IT IS VERY IMPORTANT TO BE NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
619socalstang is offline   Reply With Quote
Old 01-25-2004, 11:34 PM   #3
speeder
I ♥ Acer
331..is the way with a power adder<img border="0" src=smileys/smiley2.gif border="0"> the oil problem has beed fix as I have been told the 331 with it's rod length is better and the piston skrit is longer<edited><editID>speeder</editID><editDate>38011.8582638889</editDate></edited>
speeder is offline   Reply With Quote
Old 01-26-2004, 12:23 AM   #4
T5superduty
Quote:
Originally Posted by speeder
331..is the way with a power adder<IMG src=smileys/smiley2.gif border="0"> the oil problem has beed fix as I have been told the 331 with it's rod length is better and the piston skrit is longer
</P>
yup</P>
__________________
Ford Racing 5.0 crate engine, Gt40 X heads, B-303 cam, 1.7 Roller Rockers, Edelbrock Rpm "air gap" Intake, 625 Demon carb, "nitrous on the way"
T5superduty is offline   Reply With Quote
Old 01-26-2004, 05:53 AM   #5
Quik
Send a message via AIM to Quik
problems with the 347 are that they dont seem to last that long. to much stress on a stock block. maybe if you bought a 'R' block there wouldnt be such a large problem.
but remember any motor built wrong will have issues
__________________
powershifting owns....
o yea if your car doesent break ur not driving it like u should
Quik is offline   Reply With Quote
Old 01-26-2004, 03:26 PM   #6
mustang50
I am getting an R-Block, but i have called a couple of places near me and 2 of them said go for a 331 and the other one said go for a 347. I think i am jus going to go with a 331.</P>
Thanks guys for the help.</P>
__________________
mustang 50
Old 01-26-2004, 06:54 PM   #7
mkspeed26
Send a message via AIM to mkspeed26 Send a message via Yahoo to mkspeed26
if you have a stronger block then go with the 347. but since you are chargin it you might have too much compression and blow it up. go 331 <IMG src=smileys/smiley2.gif border="0">
__________________
1989 ford mustang lx (project car)
1993 dodge dakota sport (junkyard truck/dd)
my car domain page- http://www.cardomain.com/memberpage/639767
mkspeed26 is offline   Reply With Quote
Old 01-26-2004, 06:57 PM   #8
speeder
I ♥ Acer
I was told the rods on the 347 have been failing...
Old 01-26-2004, 07:08 PM   #9
mkspeed26
</P>
different kits have different rods. what kit are u talkin bout, the ford racing??i wouldnt get that anyway, i would make my own . trick flow crank &amp; pistons, eagle rods, Speed Pro bearings, sealed power oil pump, ARP bolts<IMG src=smileys/smiley2.gif border="0">btw you can get all that at www.summitracing.com </P>
__________________
Old 01-26-2004, 08:15 PM   #10
619socalstang
Thanks.</P>
347 kit do not burn oil any more unless you get an old set up. must use 5.315 rods www.speedomotive.com . they make kits for forced induction/low compression.<edited><editID>619socalstang</editID><editDate>38012.7375347222</editDate></edited>
__________________
331, 347, burn, compression, ford, kit, low, motor, motors, oil, pro, speed, stroker, strokers, stronger, vs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
