Injector HELP!!!!
Injector HELP!!!!
Hey guys well im installing my 30# injectors and my motor won't turn over i came to the conclusion that it is the injectors not getting any fuel through them now i put one of my 19#ers back in and it puts fuel through it so i dont know why these are not working is there something i need to do....maybe computer wise or what? The injectors are used but for only 3,000 miles from an 03 cobra is there anyway EVERY SINGLE injector could not work. Or are these injectors not for my car the part is #M-9593-B302 from ford racing. Please help me TIA!
RE: Injector HELP!!!!
ORIGINAL: ikeybmg
yea you have a big prob here. you should not even need 24lb. and you should hace the maf meter calibrated for which size inj. youre using
I looked at the part number on summit and it says 87-93 ford mustang gt 5.0 302
ORIGINAL: Tims 88GT
no he needs 30's because he is using a 125 shot. but yea you got the wrong injectors, i cant belive they hooked up right[&:]
Whats the pressure set at? Try this, turn the key to engage pump and then Lower the PSI to about 25-30 and see if it starts, if it doesnt I would send them back to ford and have them either get you some new ones or find the problem.
well he said fuel is not comming out of the injectors, in your first post you said they were out of a 03 cobra. if that is so i almost positive the connector is wrong, now put you 30's back in, get in the car, and turn the key on so you hear the pump come on, turn it off and turn it on a few times to get fp up, than crank it over for a few seconds and see if you are getting fuel out of the injector.
