best 347 setup!
best 347 setup!
ok, so i finally got my 91' GT. such a different car than the rex...but we won't go into that. i was looking at getting a 347 short block from chp (or if you have better suggestions, let me know), and i was wondering about the best heads/intake manifold combo to add on. i was thinking the trick flow track heat, but the chp long blocks come with the edelbrock, i was just wondering which has proven to be better. thanks
RE: best 347 setup!
i have never ran a 347 but spend at least a month researching the motor and the set up i would sugest is run edelbroch rpm profermer heads, and a rpm profermer intake or typhoon is the same thing. and for the 347n kit its self i would be sure to get the 5.315 rods rather than the 5.400 rods and a hyp. piston made to fit no flycut forged, no need for a forged anything unless u upgrade to a better block, trust me you cannot make surious hp with a stock block, and for the price of a after market block u can get a 351w block and all the machine work done for a 393,408 or bigger, so inconclusion you can build a 408 stroker for the same price as a 347 if you want to go over 450 hp with the engine. the kits are a bit more, but the heads and every thing else is the same.
RE: best 347 setup!
eagle sells a really nice kit through jegs for a 347. it is balanced and everything for $1600. it is what im looking into getting. as for the rest, look into the trick flow kit in summit
RE: best 347 setup!
isn't that just the stroker kit though, not the short block? i'm the same way with trick flow, but it's more of a personal opinion rather than factually based decision...so i'm just trying to get the facts. thanks though
RE: best 347 setup!
haha, i'm on a budget...i know a budget usually means carb'd...but i want efi, so i'm thinking efi 351 would cost some cash...would be very nice though [sm=smiley15.gif]
RE: best 347 setup!
where's the best place to buy a 331 short block? and how much power can be had from the 331 setup?
edit-not sure if it makes much of a dif to you but the chp 347 does use forged parts
