351 heads on 302 block
Old 02-23-2004, 10:10 PM
nemethjames1
nemethjames1's Avatar
Default 351 heads on 302 block
do 351 heads bolt right up? and is it worth it? or pointless?
nemethjames1 is offline
Old 02-24-2004, 04:30 AM
horatio102
horatio102's Avatar
Default RE: 351 heads on 302 block
iirc 351 heads are different, as are the 351 intake manifolds
horatio102 is offline
Old 02-24-2004, 11:22 PM
nemethjames1
so the heads wont bolt up? i got 351 heads and a 351 intake and a 302 block
Old 02-24-2004, 11:42 PM
hotrodman
I ♥ Acer
hotrodman's Avatar
hey dude thats a bunch of bull****,,,,351 w heads,will bolt ,,have to use special washers under the head bolt thats it,,can use same manifold ,,i just your are TALKING A WINSOR NOT A CLEAVLAND...???the only sence i see in this swap is because of the older heads with the smaller chambers,,to bump the compression,,and the lager valves..right??thaty will bump you up 2 points in compression ,,as you 9.1 to 1...you have close to 11.1 to 1,,,,same every thing ,, you will have to use adjustable rockers..
[IMG]local://upfiles/3882/Us551968366.jpg[/IMG]
hotrodman is offline
Old 02-25-2004, 06:43 AM
n2o44
n2o44's Avatar
if you do some port work to the older 351 heads you can get prety good number out of them over stock and say the gt40p irons , i got the older ones with alot grinding to pretty good numbers . if your on a budget i a good way to go.
n2o44 is offline
Old 02-25-2004, 07:08 AM
TheGmKiller331
I ♥ Acer
TheGmKiller331's Avatar
Unless you go through the time and trouble to do the porting it is not worth it.
My heads are 351's off a 78 351 out of a T-Bird and by the time i got done i could have easily bought some new heads.But again i did all my own work and then had the valve job done and milling done by a shop since i dont have acess to those machines.
It was however a good learning experience and if you are on a budget like i was thats a good way.If time is of the essence then buy some HIPO heads if funds permit.
TheGmKiller331 is offline
Old 02-25-2004, 08:16 AM
horatio102
horatio102's Avatar
Is the 351 intake manifold not wider?
Old 02-25-2004, 09:22 AM
IBSTROKN
IBSTROKN's Avatar
It will work, BEEN THERE DONE THAT!!!! It will work.
302 Cobra Block with 351 Cast Iron Shaved Heads...The heads are for sale....anyone want them?
IBSTROKN is offline
Old 02-25-2004, 10:49 AM
Turtle
Turtle's Avatar
Be carefull! I have 351W heads on my 302 and I have to run high octane. Granted, I want the high compression (with dome tops) and you may as well.But, unless you want to spend more on gas and octane boost or 110, then I suggest that you may want to consider other options. 110 does not come cheap (3.79 gal here in MI). This combo is not cruiser friendly. I love the performance, as this car is not my daily. With the porting and polishing, you can improve horse significantly.
Turtle is offline
Old 02-25-2004, 10:59 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
ORIGINAL: horatio102
nomainfolds the same on the head swap.. use same 302 intake,,,351w blocks are wider but not when putting 351w heads on a 302 block ,,,i had D00E CASTING HEADS ,,1970,,SHAVED .010,, 58ccs,,,1.84/1.54 valves...port matched just sold a set a had for $400.00,,with rocker arms,,head bolts in washers....they ehere alot better than the day 78 which had 68ccs,,,,dont waste your time if you have them ,,,D00E CASTING ...
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Florida Regional Chapter
09-30-2015 08:04 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 351 heads on 302 block
