When alternator is going or voltage regulator
Old 03-16-2006, 12:35 AM
philly3384
philly3384's Avatar
Default When alternator is going or voltage regulator
Could it make the car run not up to par becuase of the low voltage it is sending.
philly3384 is offline
Old 03-16-2006, 12:38 AM
ckyguy68
ckyguy68's Avatar
Default RE: When alternator is going or voltage regulator
yes, when my alternator went bad, for a short period of time i was running straight off the battery. at about 3500 rpm the car would just bog down. i bought a new alternator, and it felt like a new car.
ckyguy68 is offline
Old 03-16-2006, 06:02 PM
philly3384
philly3384's Avatar
what brand alternator did u get... how long were the symptoms of the car doing this or did it just happen out of nowhere.
Old 03-16-2006, 06:34 PM
ckyguy68
ckyguy68's Avatar
i just got a boshe from murrays. the systoms came up one day. a day later i was driving and the car started to stutter and stall, and i realized my voltage was gone. i installed the new alternator, and ran like a champ.
ckyguy68 is offline
joelacer
joelacer's Avatar
I don't mean to hijack the thread but I might have the same problem. My engine seems to really crap out about 4500 rpm, and my alternator gauge needle is usually on the low side of "normal" . So is my alternator going out, or is it just the way the 5.0 engine is at high rpms?
joelacer is offline
Old 03-16-2006, 06:38 PM
ckyguy68
ckyguy68's Avatar
the 5.0 may not be a high rpm engine, but it should NOT be crapping out at 4500 rpm. are there anysigns of low voltage? does the engine turn over slower? i noticed that when i had my problem. also, is it the origional alternator? if it is, i cant hurt to buy a new one.
ckyguy68 is offline
Old 03-16-2006, 06:43 PM
joelacer
joelacer's Avatar
The only signs of low voltage are the semilow needle on my alternator guage, which seems to move a bit more than it should. also, it takes a few seconds and the engine turns over a few times before its starts. Thats part of why I'm changing the spark plugs.
joelacer is offline
Old 03-16-2006, 06:45 PM
ckyguy68
ckyguy68's Avatar
the plugs could be your problem. change those and if that doesnt work i would go to fuel pump next. its most likely not your alternator, unless you are seeing obvious signs.
ckyguy68 is offline
Old 03-16-2006, 06:55 PM
88BlueGT
88BlueGT's Avatar
+1
88BlueGT is offline
Old 03-19-2006, 09:39 AM
philly3384
philly3384's Avatar
anyone else
Quick Reply: When alternator is going or voltage regulator
