bent car-help?
bent car-help?
I have a 93 5.0 that sits about one inch lower (front and back) on the left side than on the right. I replaced the springs and shocks with the eibach pro springs and tokico shocks and struts thinking it would help but it didn't. The chasis seems to be straight because like I said, the whole left side is one inch lower. It appears that the previous owner ran over something on the passanger side because I have had to replace the fuel tank due to a large dent on the passanger side and the radiator support has been bent up on the passanger side also. The car also drives straight with no problem. Could this be a suspension problem????? Any help would be greatly appreciated. Thanks.
RE: bent car-help?
some cars just sit lower on one side. my truck sits lower on the driver side by a 1/2 inch cause of the weight of the fuel tank. your car might be heavier on the passenger side. if it drives normal dont worry about it
RE: bent car-help?
no, the car is in great shape, already gone through it, it just sits lower for some reason. i dont mind it too much because with caster camber plates adjusted corrcetly on it my tire wear is fine but it is a little annoying, and sometimes it is worse than others. it goes from 1/4" lower to a full inch.?.?.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
