RPMs are so high!!
RE: RPMs are so high!!
He needs to measure the diameter of his tire from tread to tread. Is that what you meant?
If it's a different diameter than stock, that will throw your speedo off regardless of your speedo gear.
gears are measured at a set tire size and that is 26 in so if your tire is smaller then 26in tall then the ratio goes up if it is taller the it goes down. in short bus terms 355 are only 355 with a 26in tall tire. your tire size is below that your motor will spin faster then a motor with a taller tire. MOST 225- 60- 15 stock size 15in tires are just around 26 tall. get a tape and go look. While you are out get us a beer.[sm=icon_cheers.gif]
ORIGINAL: uedlose
ORIGINAL: Twisted
As I mentioned in my other post, I just got 3.55s installed today. I just now went out and beat on the car a bit. Wow!! Huge difference!! At any rate, I took the car on the highway, and at an indicated 70mph, it seems like I was awfully close to 3k rpms. Not only that, it felt like I was actually going faster than 70mph. I'm starting to wonder whether the shop installed the correct speedo gear. Anyway, my questions are:
1. Do these rpms seem normal for 3.55s?
2. I'm driving across the country in a few months. Can my 302 handle those rpms for 3k miles?
2. probably wouldnt hurt to not drive so damn fast
here are a few questions i have for you....
Did the installer change out your speedometer gear?
If so, which one was installed?
ORIGINAL: AdderMk2
25.6" actually
1. no. at 80 mph you should be at 2500 rpms with a t-5 manual in 5th gear
ORIGINAL: uedlose
ORIGINAL: Twisted
ORIGINAL: Tims 88GT
u know u need a 23 tooth right?
