Help with TRANSGO kit!
RE: Help with TRANSGO kit!
how does it work, can u just shift with the selector or do u let off the gas to shift or wat. cuz it says u can hold it to any rpm and downshift whenever? please help explain if u could
Welll I took it for a test drive after checking the TV valve adjustment ant it works great. I installed the Firm shift setup because the tech from transgo rcomended it with the 4.10 gears and after driving it I m glad that I did because it shifts hard. It holds any gear to as high as I wanted to run it in RPM and at 2/3 trottle it chirps the tires nice between 1st and 2nd and 2nd to 3rd. At WOT it is a little scarry, did not see the 1st to 2nd shift I think it was around 5000 and the 2nd to 3rd it was right at 5500. When down shifting manually it shifts with out delay. All in all I think I like it but I still think I want to look for a 5 speed. Hope this helps! If You have any other questions post them and I will try to answer them the best I can (My grammer and spelling is not that great!!)
Thanks for all the help! Preston
jwog666
12-27-2021 08:09 PM
