What's that noise?
RE: What's that noise?
usually when your fuel pump get that loud it is about ready to go out. replace it and it should hep withthe noise. check to see if the sound deading insulation is in place in the trunk also.
definitely is the fuel pump! they are noisy by nature but when they whine that loud, they're usually on their way out. helps to run the tank at least half full so the pump stays cooler, running the tank almost empty is not a good thing for an in tank pump! you might change the fuel filter first though because if it's almost plugged, it's making the pump work harder and that could be why it's whining and the filter is a whole lot easier to check/change than the in tank pump!
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
