[Deleted]
RE: a few tech questions
Just the starter spins? Or is just the motor spining? Suggestion i have is to check your plugs and wires first. Has there been any mods to the car? Since you just bought the car i would go get a tune up or do it yourself . Its usally the simple things even could be a clogged fuel filter. But give some more info if you could . Good Luck!!
If the contacts in the distributor cap are coroded and/or the rotor then that wouldn't help your engine run well. That's def something you should do anyways since you don't know how old the ones on there are.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
