Carb to efi
RE: Carb to efi
ORIGINAL: HACKGT350
damn and thats in a fox? how does that fit haha
RE: Carb to efi
ORIGINAL: turt
WHaaaaaaaat???????????
[/quote]Sure we have built these big blocks regularly at those numbers on 93 octane. Its all about effieciency, we all know its easy as pie in a big block to make 1hp per cubic inch, and thats on a smog motor from the 1970's. Now your at 550-600 inches, so all it takes is a little over 1.5 hp per inch to make these numbers.
RE: Carb to efi
ORIGINAL: turt
im gunna have to try a big block for my mustang soon.... Too bad I just spent over $10,000 in parts on this 347.
Is still fun on the streets of connecticut though.
i
i
RE: Carb to efi
ORIGINAL: myshifter
Well like I said alot of people are cool with a small block, with emissions and all. But 10k on a small block versus 6k on a big block that will turn circles around that small block would be a hard pill for me to swallow. I would be sick, im sure its plenty of fun though
ORIGINAL: tur
i
i
6k from scratch? hmmmmmmm
RE: Carb to efi
ORIGINAL: turt
ORIGINAL: myshifter
ORIGINAL: tur
i
i
RE: Carb to efi
but, seeing as that everything minus the ecu would be replaced at some point why not? i mean new upper and lower intake, distributor, ignition, fuel pump, MAF sensor,injectors and so on. also, i want a Kenne Bell blower.
ORIGINAL: HACKGT350
if i were you i would find a doner with efi its going to be expensive to convert it back to efi from carb my car is carb and i dont have a problem with it i would drop the engine in and see how you like it before you deside to switch
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
