map sensor
RE: map sensor
ok i went and checked tps, it was .87 moved it to .97 and undid battery. started back up and same problem. the thing is i can pull that plug off the vaccum tree(the one i put on from the map sensor) and let it suck air and the car will pretty much idle fine just little high maybe but put the plug back on the surge starts again. any thoughts on that?
RE: map sensor
ORIGINAL: bobbymorris26
RE: map sensor
well went through the steps provided above, and have drove the car twice and i have no more idle surging. I think the dirty throtle plate was my problem, it was black around it. i may have my idle set little high now though its running around 1000rpm what do you guys recommend? thanks for the help.
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
TfcCDR
09-14-2015 12:08 PM
