AHHAA! Idle Problem Solved....Kinda
Old 05-11-2006, 02:29 AM
5.0 MPG
5.0 MPG's Avatar
Default AHHAA! Idle Problem Solved....Kinda
Alright for those of you that remember I had a idle problem at start up for about 1 minute. Well while I was adjusting my base idle and waiting for it to settle I unplugged the vacuum line to my EGR and bam! it fixed itself! So here is my question. I took off all the smog crap, do I need to have this line pluged to the EGR? I drove around the block without it and everyhting felt fine. Any ideas?
5.0 MPG is offline
Old 05-11-2006, 03:02 AM
5.0 MPG
5.0 MPG's Avatar
Default RE: AHHAA! Idle Problem Solved....Kinda
bump
5.0 MPG is offline
Old 05-11-2006, 03:11 AM
Tims 88GT
Tims 88GT's Avatar
ok so u dont have the smog junk? if not than u can take the vac line off of the egr. BUT that should not change vaccum because with out the vaccum hooked up for the smog that has no vaccum.
Tims 88GT is offline
Old 05-11-2006, 03:22 AM
5.0 MPG
5.0 MPG's Avatar
Thats why I never suspected it in the first place with the idle problem. Maybe the EGR is clogged? Who knows.
What does the EGR do anyway Tim?
5.0 MPG is offline
Old 05-11-2006, 03:24 AM
Tims 88GT
Tims 88GT's Avatar
go to the HELLA HOT thread and start reading that, im learing as well lol.
Old 05-11-2006, 03:26 AM
5.0 MPG
5.0 MPG's Avatar
gotcha!
Thanks.
5.0 MPG is offline
Old 05-11-2006, 11:30 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: 5.0 MPG
You shouldn't have vacuum at the EGR valve line engine idling. You might want to recheck your vacuum line routing....if you removed the smog stuff, all you need is a vacuum supply line to the EGR Valve Regulator (EVR) solenoid (this line would have vacuum @idle) and a line from the EVR to the EGR valve. The EVR is the solenoid the EEC-IV system activates to open the valve during part-throttle load conditions....never @WOT or engine idling. My 2¢.
Joel5.0 is offline
Old 05-11-2006, 12:16 PM
ikeybmg
ikeybmg's Avatar
where did you end up setting the base bro?
ikeybmg is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: AHHAA! Idle Problem Solved....Kinda
