gauges
gauges
ok im taking out my gauge cluster and fabbing my own to go in. im going to using autometer ultra-light series.
ill be getting the 160 speedo new tach water temp fuel pressure oil pressure oil temp voltmeter
they are all going to look like this speedo gauge i am going to use the original face that goes over the cluster the plate that holds everything in is just going to be different what do you guys thing? too many gauges or no? the ones that arnt going in the cluster are going to be on the outside of the car in the cowl vent they just started making with the pods built into them
http://www.mustangsunlimited.com/ite...=&catkey=74-01
oh and does this air fuel ratio gauge really work?
RE: gauges
RE: gauges
ORIGINAL: PRO50SC
+1, I wish they would have had that when I was doing mine. As far as the a/f gauge goes, It's not like a wide band but it will let you know when there is a fuel issue.
ok cool but i think it will help me out a little more than you guys cause my car is carburated and i know im running rich right now i really think its the boush platinums i put in i gotta take them out and put in some good ol autolights
RE: gauges
its not hard to make that plate that holds the gauges and i dont like theirs cause its offset and looks like a half *** job so i figure ill make it myself and just put all the gauges in myself i like doing stuff like that myself instead of buying it pre built it even said in the artical they are having problems with it so i dont want to deal withthat
